Home > Forums > Visualization & Post-Processing Software > ParaView
[General] export picture messy problem
Old   January 6, 2014, 04:19
Default export picture messy problem
chenxizhong
chenxizh is on a distinguished road
Hi, all , I have a problem when I load paraview in Linux and export the picture, the picture seems messy. However when I did it in Windows system, everything is right. Do anybody face the same problem before? How to solve it ? Thanks.
Following is the picture from Linux and windows system as an exmple.
chenxizh is offline   Reply With Quote
Old   January 10, 2014, 15:38
Retired Super Moderator
Bruno Santos
Greetings chenxizh,
It's very possible that you are having problems with the graphics driver. Perhaps you haven't installed the correct one in your Linux system?
Knowing more about your set-up would make it easier to help you. For example:
  1. Which Linux distribution are you using? And which specific version and architecture?
  2. Which ParaView version are you using?
  3. How did you install ParaView?
  4. Did you install the drivers for the graphics card?
  5. Do you know which graphics card you have in your machine?
Best regards,
Bruno
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer wildfire230 OpenFOAM Installation 20 May 6, 2020 07:30
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 00:17
[ICEM] problem export 2d geometry Marcuse ANSYS Meshing & Geometry 7 January 26, 2015 14:34
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
