January 20, 2014, 11:19 |
specific filter in paraview
ziehjay
Rep Power: 12 |
hey guys,
i am looking for a filter which could describe my velocity of my fluid (water) on a imaginary line for for example) 40 points on this line. these 40 points should create at the end a graph with x-and y axis which shows the behaviour of my velocity at every single point. i hope the attached picture helps you to understand what i mean. is there such a filter in paraview? if not, is there an alternative to describe it in a smiliar way? unfortuanatley i did not find anything in paraview so far. thank you guys |
January 20, 2014, 11:39 |
The picture you've provided corresponds to 'Plot over line' filter. |
January 20, 2014, 11:53 |
ziehjay
Rep Power: 12 |
hey this function was deactivated when i tried this based on research on the internet.After i updated paraview it worked.
Thank you very much at all. This is what i was looking for! |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 02:32 |
