Home > Forums > Visualization & Post-Processing Software > ParaView
[General] pvbatch script for saving animations modifing each frame
Like Tree3Likes
  • 2 Post By wyldckat
  • 1 Post By Gaetano
Old   October 29, 2013, 12:18
Default pvbatch script for saving animations modifing each frame
Gaetano
Gaetano is on a distinguished road
Hi all.
I'd like to have your inputs on a problem that is puzzling me from days.
I want to save an animation starting from a series of vtk. Apart from the rendering of a point field, I need a line source to be superimposed. The coordinates of the two points defining the line have to be read from a text file (two points for each vtk).
I managed to create an image sequence, that is to export each single frame of my animation. Now I'd like to have only an .ogv as output of my python script.
I tried something like the script here, but I wasn't successful:
ERROR: In /root/ParaView-v4.0.1-source/ParaViewCore/ClientServerCore/Rendering/vtkPVCameraCueManipulator.cxx, line 94
vtkPVCameraCueManipulator (0x1ed8d550): No camera to animate.
./video3.sh: line 5: 25353 Segmentation fault /share/paraview-4.0.1-MESA/bin/pvbatch --use-offscreen-rendering screen3.py
Of course the error comes from the fact that I'm not animating the camera.
Another hint is here, where the suggestion is to put the rendering instructions into a "Python script to be called on every timestep" using the "Python Animation Cue". Nonetheless I couldn't find any reference/example on internet.
Any suggestion?
PS: the rendering instructions are those I could register using the GUI tracing tool
PPS: I'm using Paraview 4.0.1 with MESA support on a Linux machine
Gaetano is offline   Reply With Quote
Old   October 30, 2013, 05:31
Default Minimal script
Gaetano
Just to give some more background, here's a minimal version of my script:
import math
try: paraview.simple
except: from paraview.simple import *
paraview.simple._DisableFirstRenderCameraReset()
# number of frames
frames = 121
# time difference between steps (needed for reconstruct filenames)
step = 0.05
# List containing the x and y coordinates of the two points
pos = [[] for i in range(frames)]
i=0
# Filename containing the coordinates in the following format:
# time x_top y_top x_bottom y_bottom
# 0.12 0.123456 0.123456 0.123456 0.123456
in_file = open("/home/project/simulation/points.out","r")
# Loop through lines in file
for line in in_file:
   [time,xt,yt,xb,yb] = line.rsplit(' ',5)
   # Store the coordinate in a 2D list
   pos[i] = [float(xt), float(yt), float(xb), float(yb)]
   i = i+1
in_file.close()
for i in range(frames):
   # Read file
   file = "/home/project/simulation/VTK/sim_" + str(int(i*step*1000)) + ".vtk"
   reader = LegacyVTKReader( FileNames=file )
   RenderView1 = GetRenderView()
   Slice1 = Slice( SliceType="Plane" )
   Slice1.SliceOffsetValues = [0.0]
   Slice1.SliceType = "Plane"
   Slice1.SliceType.Origin = [0.0, 0.0, 0.0]
   Slice1.SliceType.Normal = [0.0, 0.0, 1.0]
   DataRepresentation1 = Show()
   DataRepresentation1.ScaleFactor = 0.05
   DataRepresentation1.SelectionPointFieldDataArrayName = 'U'
   DataRepresentation1.EdgeColor = [0.0, 0.0, 0.5]
   a1_U_PVLookupTable = GetLookupTableForArray( "U", 3, RGBPoints=[0.0, 0.0, 0.0, 1.0, 1.0, 1.0, 0.0, 0.0], VectorMode='Magnitude', NanColor=[0.5, 0.5, 0.5], ColorSpace='HSV', ScalarRangeInitialized=1.0, LockScalarRange=1 )
   a1_U_PiecewiseFunction = CreatePiecewiseFunction( Points=[0.0, 0.0, 0.5, 0.0, 1.0, 1.0, 0.5, 0.0] )
   DataRepresentation1.ColorArrayName = 'U'
   DataRepresentation1.LookupTable = a1_U_PVLookupTable
   Line1 = Line()
   Line1.Point1 = [ pos[i][0], pos[i][1], 0.0]
   Line1.Point2 = [ pos[i][2], pos[i][3], 0.0]
   DataRepresentation2 = Show()
   DataRepresentation2.ScaleFactor = 0.02
   DataRepresentation2.SelectionPointFieldDataArrayName = 'Texture Coordinates'
   DataRepresentation2.EdgeColor = [0.0, 0.0, 0.5]
   DataRepresentation2.LineWidth = 3.0
   RenderView1.ResetCamera()
   RenderView1.CenterAxesVisibility = 0
   RenderView1.OrientationAxesVisibility = 1
   RenderView1.ViewSize = [ 2400, 2400 ]
   ScalarBarWidgetRepresentation1 = CreateScalarBar( ComponentTitle='', Title='U', Enabled=1, LabelFontSize=12, LookupTable=a1_U_PVLookupTable, TitleFontSize=12, Position=[0.9, 0.25] )
   GetRenderView().Representations.append(ScalarBarWidgetRepresentation1)
   WriteImage('/home/project/frames/video' + str(int(i*step*1000)) + '.png')
   # Memory saving?
   Delete(reader)
   Delete(Slice1)
   Delete(Threshold1)
   Delete(Contour1)
   Delete(Line1)
It basically built each frame from scratch and save it as png. I know that it looks horrible, but I'm a beginner in both python programming and paraview scripting.
Is there a way to save an .ogv starting from those frames?
Any comments on the script are extremely welcome!
Old   November 2, 2013, 16:09
Retired Super Moderator
Bruno Santos
Greetings Gaetano,
Wow, that's some heavy duty coding you want to perform! And for pvbatch, to top it off!
Personally, I prefer to use GUI first for testing. And ParaView has got a marvellous feature in the "Tools" menu, namely "Start/Stop Trace". This allows us to register most of the commands we executed graphically and when we stop tracing, we get a script which most of the times gives a good code to start with. Problem is when it doesn't give us all of the code we need
But in this case, I did a quick test, and the following pearls of wisdom it gave me were (with ParaView 3.12.0):
  1. We can load a timeline of VTK files with something like this:
    cavity_ = LegacyVTKReader( FileNames=['/home/user/mycase/cavity_0.vtk', '/home/user/mycase/cavity_20.vtk', '/home/user/mycase/cavity_40.vtk', '/home/user/mycase/cavity_60.vtk', '/home/user/mycase/cavity_80.vtk', '/home/user/mycase/cavity_100.vtk'] )
  2. We can switch to another time frame by using this code:
    AnimationScene1 = GetAnimationScene()
    AnimationScene1.EndTime = 5.0
    AnimationScene1.PlayMode = 'Snap To TimeSteps'
    AnimationScene1.AnimationTime = 2.0
    RenderView1.ViewTime = 2.0
    where 2.0 is the frame (time) I wanted. It will load up the respective data from the VTK file automatically.
  3. The embedded code to be executed on each time frame is done like this:
    PythonAnimationCue1 = PythonAnimationCue( Script='def start_cue(self): pass\n\ndef tick(self): pass\n\nprint(self)\n\ndef end_cue(self): pass' )
As for coding the cue code, the best I can provide is the example I wrote some time ago here: http://www.cfd-online.com/Forums/ope...tml#post446333 post #6.
As for saving to OGV... on ParaView 4.0.1 I got this from the Python trace feature:
WriteAnimation('/home/user/mycase/test.ogv', Magnification=1, Quality=2, FrameRate=15.000000)
Best regards,
Bruno
Nucleophobe and Taataa like this.
Old   November 4, 2013, 12:08
Thumbs up
Gaetano
I know: all the code above was a modification of the output of the trace tool (first Post Scriptum in my first message).
Here's how to move between frames, at least! But actually the definitive hint is:
Eventually, I managed to create the video I wanted. I used also the minimal script I found here: it told me how to use that "PythonAnimationCue".
For future reference (and my 2 cents for the community), here's how I did it:
# number of frames
frames = 121
step = 0.05
AnimationScene1.EndTime = frames-1
i=0
   i = i+1
in_file.close()
   # Read file
   files.append(file)
reader = LegacyVTKReader( FileNames=files )
Line1 = Line()
PythonAnimationCue1 = PythonAnimationCue()
PythonAnimationCue1.Script= """
def tick(self):
   i = int(GetAnimationScene().TimeKeeper.Time)
   RenderView1.ViewTime = i
   AnimationScene1.AnimationTime = i
   Line1 = FindSource("Line1")
   Line1.UpdatePipeline(GetAnimationScene().TimeKeeper.Time)
AnimationScene1.Cues.append(PythonAnimationCue1)
WriteAnimation('/home/project/frames/video.ogv', Magnification=1, Quality=2, FrameRate=8.0)
Thanks Bruno: you really made my day!
Regards,
Gaetano
wyldckat likes this.
Old   January 30, 2014, 05:42
Gaetano
Errata corrige: my script seems to put the line at the previous instant into the current instant photogram. There is still something wrong, so be careful if you're going to use it.
Regards,
Gaetano
animation, frame, pvbatch, python
Coordinate Frame Motion yangxu CFX 6 January 25, 2022 08:51
Split connectors at their intersection FOUAD12 Pointwise & Gridgen 3 October 8, 2018 10:42
TUI Command for Cell Zone Condition? artkingjw FLUENT 2 February 25, 2018 07:38
Moving reference frame for turbine simulation Rahl141 STAR-CCM+ 2 December 28, 2017 06:25
Convert DFT of pressure in rotating frame to stationary frame CFD-123 FLUENT 0 February 12, 2015 17:51
