Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Viewing static pressure and temperature in Paraview
Like Tree2Likes
  • 1 Post By badboyz31
  • 1 Post By wyldckat
Old   February 20, 2014, 03:43
Default Viewing static pressure and temperature in Paraview
badboyz31 is on a distinguished road
I've been running a simulation of a wedge airfoil in supersonic flow. After the iteration is done, I went to Paraview. I am able to see several parameters such as p, rho, u, etc. but I don't see static pressure and static temperature. When I click on p, the legend showed that most area in the flow field has the value of total pressure I given as boundary condition.
What should I do to show static pressure and temperature distribution ?
mizzou likes this.
badboyz31 is offline   Reply With Quote
Old   February 22, 2014, 11:07
Retired Super Moderator
Bruno Santos
Greetings badboyz31,
Are you referring to the tutorial "compressible/sonicFoam/ras/nacaAirfoil"? Or at least based on it?
And I've done a bit of Googling:
site:cfd-online.com "openfoam" sonicFoam static pressure
Which gave me these threads:
From what I basically know and from what I can understand, the "p" field usually refers to static pressure and total pressure can be calculated by running the utility ptot. There is also the function object "pressureTools", which can be found from here: http://foam.sourceforge.net/docs/cpp/modules.html - click on the "Utility function objects" link (it will change with each release of OpenFOAM, which is why I don't give a direct link).
As for static temperature... I have no idea what that is or at least I can't remember...
Best regards,
Bruno
mizzou likes this.
Old   February 26, 2014, 06:02
Well, thanks mate. I'll be reading it for a while
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
Turbomachinery, transient flow - temperature limited and pressure AMG divergence dariuszkoz FLUENT 0 January 2, 2019 08:43
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
