Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Generating vtu and pvtu files
Like Tree1Likes
  • 1 Post By yosuke1984
Old   October 14, 2013, 12:36
Default Generating vtu and pvtu files
tylergug is on a distinguished road
I am new to this forum and paraview as well. I have some large vtk files that need to be processed, and to process them in parallel I believe that I would need to split them up into multiple vtu files. Then have a pvtu file combine them into a single object. However, I do not know how to split these vtk files into vtu and so on. Does anyone have any experience in this? Any help and information would be greatly appreciated.
Thanks in advance,
Tyler
tylergug is offline   Reply With Quote
Old   October 16, 2013, 11:28
Anybody? I haven't been able to find much information on the web about this
Old   October 17, 2013, 12:02
William Humber
whumber is on a distinguished road
Easiest way would probably to just partition them with something like metis or scotch and then convert each partition to its own .vtu file.
whumber is offline   Reply With Quote
Old   March 11, 2014, 13:03
Default Re Generating vtu and pvtu files
yosuke
yosuke1984 is on a distinguished road
This is my pvtu and tria vtu samples.
Basically, a pvtu file is a parent. It calls material1.vtu and material2.vtu files.
If you read the pvtu file, paraview automatically read all the sub domain vtu files.
From your problem size, I believe your problem is domain decomposed. If not use graph partitioners like metis, scotch or chaco. Then it is easy to created each vtu files. Just assign each domain mesh and variables for a vtu files.
Then modify followings according to the number of domains.
<Piece Source="material1.vtu"/>
<Piece Source="material2.vtu"/>
<Piece Source="materialN.vtu"/>
parallel.pvtu
<?xml version="1.0"?>
<VTKFile type="PUnstructuredGrid" version="0.1" byte_order="LittleEndian">
<PUnstructuredGrid GhostLevel="0">
<PPoints>
  <PDataArray type="Float32" Name="Position" NumberOfComponents="3"/>
</PPoints>
<PCells>
  <PDataArray type="Int32" Name="connectivity" NumberOfComponents="1"/>
  <PDataArray type="Int32" Name="offsets"      NumberOfComponents="1"/>
  <PDataArray type="UInt8" Name="types"        NumberOfComponents="1"/>
</PCells>
<PCellData Scalars="Material">
    <PDataArray type="Int32" Name="Material" NumberOfComponents="1"/>
</PCellData>
</PUnstructuredGrid>
</VTKFile>
material1.vtu
<VTKFile type="UnstructuredGrid" version="0.1" byte_order="LittleEndian">
<UnstructuredGrid>
<Piece NumberOfPoints="3" NumberOfCells="1">
<Points>
  <DataArray type="Float32" Name="Position" NumberOfComponents="3" format="ascii">
    0.0    0.0    0.0
    1.0    1.0    0.0
    0.0    1.0    0.0
  </DataArray>
</Points>
<Cells>
  <DataArray type="Int32" Name="connectivity" NumberOfComponents="1" format="ascii">
    0    1    2
  </DataArray>
  <DataArray type="Int32" Name="offsets" NumberOfComponents="1" format="ascii">
    3
  </DataArray>
  <DataArray type="UInt8"  Name="types" NumberOfComponents="1" format="ascii">
    5
  </DataArray>
</Cells>
<CellData Scalars="Material">
  <DataArray type="Int32" Name="Material" NumberOfComponents="1" format="ascii">
    1
  </DataArray>
</CellData>
</Piece>
</UnstructuredGrid>
</VTKFile>
material2.vtu
<UnstructuredGrid>
<Points>
    0.0    0    0
    1.0    0.0    0
    1.0    1.0    0
  </DataArray>
</Points>
<Cells>
    0    1    2
  </DataArray>
    3
  </DataArray>
    5
  </DataArray>
</Cells>
    2
  </DataArray>
</CellData>
</Piece>
</UnstructuredGrid>
</VTKFile>
wyldckat likes this.
yosuke1984 is offline   Reply With Quote
