paraview isolines
hi
is it possible to do isolines over a clipped surface, with the actual numbers on the isolines for pressure or velocity magnitude? thanks jas |
Greetings jas,
In ParaView, it's possible, but not easily done. The only two possible solutions I can find are:
You might also want to ask for this feature at ParaView's bug tracker and/or ParaView's UserVoice:
Best regards, Bruno |
Hi Bruno,
I hope this doesn't seem to off-topic but this thread is the only hit for "matplotlib in ParaView" on the forum. Have you managed to build ParaView 4.1.0 and use the new matplotlib capabilities? My installation: OF23x on SL 6.5 largely following your excellent instructions over on the OpenFOAMWiki. For ParaView, I've set the python (and mesa) option to true in makeParaView4. Prior to build python 2.6.6, numpy 1.4.1 and python-matplotlib 0.99.1.2 were installed via yum. Qt 4.8.5 is built from source. Compiler is clang 3.3. ParaView builds without error and python scripting features work fine, but if I try to open a "Python View" to do some matplotlib plots, I get the following error: Code:
ERROR: In /home/william/OpenFOAM/ThirdParty-2.3.x/ParaView-4.1.0/ParaViewCore/ClientServerCore/Rendering/vtkMatplotlibUtilities.cxx, line 302 |
Problem solved: removed SL python-matplotlib 0.99.1.2, built and installed matplotlib-1.2.0. (Thanks to Cory Kwammen at Kitware.)
1 Attachment(s)
Hi Jas,
I was looking for a similar solution and I came across your thread. There is another possibility that hasn't been mentioned here… It is a bit tedious but the results are nice. 1. You need to have first the contour lines. 2. Make a slice over the contour lines you want to label (in order to make points) 3. Select the points you just created. 4. Open the selection inspector and make the label of the points “visible”. 5. You can choose the format of the float number (i.e. %.2f), the color, size etc.. Note: the picture attached uses a constant value just for illustration purposes. This method has been taken from the following paraview thread: http://public.kitware.com/pipermail/...er/018798.html Regards, Javier |
Non-steady isotherms/ Slice misfit
The solution given here assumes that these contours will be steady. I have a simulation in which isotherms change during the model evolution, which means that slices will not fit in the isotherms for other time intervals. Is there any other way just to put the values of isotherms on the lines as we do in MATLAB? Cheers Omer |
