No point values for U in Paraview?
2 Attachment(s)
Hello foamers,
I am trying to plot streaklines in ParaFoam, and I am running into problems each of two ways: - Using paraFoam in OF 2.1.1 (paraView 3.12), Streaklines is not available as an option - Using paraView 3.98RC which I compiled from source (to allow python functions), Streaklines will not plot U because it is not available as a point value - though it is available as a cell value. Strangely, U does appear as a point value if I run paraFoam, vs opening paraView 3.98 and then loading the case by first running "touch case.foam" in the case directory. Please see attached screenshots that illustrate the difference. Can anyone suggest how I might get around these issues to plot streaklines? Thanks in advance, Daniel |
Greetings Daniel,
That's very very strange... namely that the U field is not being interpolated to the points. It's possible that this is a bug in 3.98 RC3 that was fixed in the final release. To go around this issue, try:
And the filter "Streaklines" was indeed introduced in ParaView 3.98. My advice: install OpenFOAM 2.3.0 from Deb packages, along with the provided custom build of ParaView 4.1.0, which already includes Python. You can then use a separate terminal window with a shell environment for 2.3.0. In case you don't know how to use more than one OpenFOAM installation, check this wiki page: http://openfoamwiki.net/index.php/In...with_the_Shell Best regards, Bruno |
Hello Bruno,
Thanks for your help! I built OpenFOAM 2.3.0 from source, enabling the flags for python in the ParaView installation, and now I can have my cake and eat it too with ParaView 4.1. Thanks again! Daniel |
