Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] OpenFOAM (2.3.0) guide for ParaView (4.1.0) is not ok with actual software
Like Tree2Likes
  • 1 Post By derekm
  • 1 Post By wyldckat
Old   March 25, 2014, 13:52
Default OpenFOAM (2.3.0) guide for ParaView (4.1.0) is not ok with actual software
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Hi friends
I installed OpenFOAM 2.3.0 and ParaView 4.1.0
I did the first tutorial "Lid-driven cavity flow" in user guide (presented in the official website of OpenFOAM).
But first of all the discribtion is not compatible with GUI in ParaView.
It seems the user guide is an old version guide.
And another problem is that I couldn't see the results as the same as in tutorial presented.
Please help me if you have the answer!!
Thank you
zandi is offline   Reply With Quote
Old   March 26, 2014, 16:09
Retired Super Moderator
Bruno Santos
Quick request: please show images of what you're seeing and to which images your referring to in the User Guide.
Otherwise, I would say that it all seems perfectly fine to me
Old   March 27, 2014, 23:16
zandi's Avatar
Hello and thank you
It was my fault in order to result. I have not specified the time which mentioned in guide. when I did it, it got to be ok.
but the paraview window is a little different from what showed in guide, in properties and display tabs,..
Old   March 28, 2014, 04:09
Derek Mitchell
derekm is on a distinguished road
I have had the same issue. The differences are sufficient to throw a new user, and small enough not to be noticed by one who is familiar.
Classic issue of testing introductory documentation:the difficulty of getting the correct level of tester and once they have run through a few times they are no longer the correct level. The act of testing changes the tester.
IMHO: However, in the scale of documentation omissions that exist in OpenFoam, this one is relatively small beer.
Fully commented files in the Tutorial examples would be higher up the list.
zandi likes this.
derekm is offline   Reply With Quote
Old   March 28, 2014, 18:08
Bruno Santos
Greetings to all!
Mmm... OK, now I remember. The detail is that the pictures in the User Guide are from ParaView 3.10 or older.
ParaView 3.12.0 was the default version for all OpenFOAM versions since 2.0 to 2.2, if I'm not mistaken. Here the differences between the images and 3.12.0 isn't very big.
Problem is that OpenFOAM 2.3 currently has support for both ParaView 3.12.0 and 4.1.0. But ParaView is 4.x is following a new interface that is considerably different. Although the mnemonic is as simple as the following:
  1. The tabs "Properties" and "Display" have been merged into a single tab.
  2. There are settings that will only appear if we press on the "Gear" button.
I guess that they will only update the images on the User Guide when they drop support for ParaView 3.12 .
Well... this is where the other detail about OpenFOAM comes in:
  1. The user must learn to spot the differences and be able to learn to correlate the information available in different versions of OpenFOAM.
  2. The user must pay close attention to any and all details.
  3. Failing either one of the 2 points above, will likely result in OpenFOAM not working as intended
AFAIK, if someone sponsors them to do it, they will do it!
Best regards,
Bruno
zandi likes this.
Old   March 29, 2014, 01:13
zandi's Avatar
Thank you friends, but is there any documentation about ParaView which can be used? (tutorial or guide)
The help of software may be useful but it just works in the ParaView window! is there any individual help document?
Old   March 29, 2014, 07:52
Bruno Santos
http://www.paraview.org/Wiki/ParaView
Old   March 31, 2014, 00:18
zandi's Avatar
Thank you very much
openfoam 2.3.0, openfoam guide, paraview 4.1.0
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
[OpenFOAM.org] How to remove manually installed OpenFOAM 2.3.0? sisi OpenFOAM Installation 2 December 23, 2014 10:09
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Best postprocessing software for OpenFOAM johannes OpenFOAM Post-Processing 3 December 30, 2007 08:34
