Home > Forums > OpenFOAM Paraview & paraFoam
Paraview arrays to numpy arrays
Old   April 10, 2014, 09:01
Default Paraview arrays to numpy arrays
Francois Beaubert
francois is on a distinguished road
Hi all,
I'm trying to use IPython with numpy to do some of my post-processing.
I've encountered the following difficulty: I'm unable to import paraview arrays into numpy ones.
Here is a simple example that read an OpenFoam case, sample the data on lines using PlotOverline filter and export them in csv files:
try: paraview.simple
except: from paraview.simple import *
paraview.simple._DisableFirstRenderCameraReset()
import math
# Define geometric parameters
D = 0.036
# Define points coordinates in cylindrical coordinates
r1 = 0.0
r2 = 0.019
theta1 = 90
theta2 = 90
theta1Rad = theta1 * math.pi/180
theta2Rad = theta2 * math.pi/180
z1 = 1*D
z2 = 1*D
# Transform points coordinates from cylindrical to cartesian
x1 = r1*math.cos(theta1Rad)
x2 = r2*math.cos(theta2Rad)
y1 = r1*math.sin(theta1Rad)
y2 = r2*math.sin(theta2Rad)
# Define the OpenFOAM data source
case_OpenFOAM = OpenDataFile('./case1.OpenFOAM')
case_OpenFOAM.MeshParts = ['internalMesh', 'wall - group']
case_OpenFOAM.VolumeFields = ['p', 'U', 'Ucyl', 'ccCyl']
for i in range(0,10):
  # Define the source data
  SetActiveSource(case_OpenFOAM)
  # Define the line
  PlotOverLine1 = PlotOverLine( Source="High Resolution Line Source" )
  zPos = i*D
  PlotOverLine1.Source.Point1 = [x1, y1, z1 + zPos]
  PlotOverLine1.Source.Point2 = [x2, y2, z2 + zPos]
  PassArrays1 = PassArrays()
  PassArrays1.PointDataArrays = ['arc_length','ccCyl','U', 'Ucyl', 'p']
  source = PassArrays1
  # Define filename of the outputs
  fileName = 'line' + '_r=' + str(r1) + '-' + str(r2) + '_theta=' + str(theta1) + '-' + str(theta2) + '_z=' + str(z1+ zPos) + '-' + str(z2 + zPos) + '.csv'
  writer = CreateWriter(fileName, source)
  writer.FieldAssociation = "Points" # or "Cells"
  writer.UpdatePipeline()
  del writer
Everything work correctly but rather than importing the data from the files into numpy arrays with loadtxt, I would prefer to import them directly into numpy arrays right after my PlotOverline: convert paraview arrays directly into numpy arrays
I know that some support functions from numpy_support are readily available for this kind of tasks:
from vtk.util import numpy_support as npvtk
vtkarray = npvtk.numpy_to_vtk(numpy_array)
numpy_array = npvtk.vtk_to_numpy(vtkarray)
I've tried to use them without success:
pParaview = case_OpenFOAM.PointData['p']
pNumpy = npvtk.vtk_to_numpy(pParaview)
But get the following error messages:
AttributeError                            Traceback (most recent call last)
<ipython-input-85-597a4d038813> in <module>()
----> 1 pNumpy = npvtk.vtk_to_numpy(pParaview)
/opt/paraviewopenfoam410/lib/paraview-4.1/site-packages/vtk/util/numpy_support.py in vtk_to_numpy(vtk_array)
    206     # Get the data via the buffer interface
    207     dtype = get_numpy_array_type(typ)
--> 208     result = numpy.frombuffer(vtk_array, dtype=dtype)
    209     if shape[1] == 1:
    210         shape = (shape[0], )
/opt/paraviewopenfoam410/lib/paraview-4.1/site-packages/paraview/servermanager.pyc in __getattr__(self, name)
   1433         array = self.FieldData.GetFieldData().GetArrayInformation(self.Name)
   1434         if not array: return None
-> 1435         return getattr(array, name)
   1436
   1437     def __repr__(self):
AttributeError: __buffer__
Any advice ?
How to manipulate paraview arrays using numpy ?
Thank you very much for your help
Regards
François
francois is offline   Reply With Quote
Old   April 13, 2014, 16:48
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings François,
I think you're overlooking an important detail with OpenFOAM related data: it's handled as "MultiBlock" data.
A few reference threads:
Best regards,
Bruno
___
I'll be at OFW11 in Portugal
Old   April 14, 2014, 08:33
Francois Beaubert
Thanks for the advice Bruno !
I will look at the threads you have mentioned
Regards,
François
Thread Tools
Trackbacks are On
Paraview version update errors Dan Pearce OpenFOAM Installation 5 January 8, 2014 06:47
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Extracting ParaView Data into Python Arrays Jeffzda ParaView 7 December 6, 2012 09:10
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 03:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
