[OpenFOAM] Calculating and Plotting Nusselt Number with ParaView |
May 25, 2014, 19:39 |
Tom
Rep Power: 12 |
Hi!
I have been working with OpenFOAM and some GUI (Helyx-OS). Am simulating cases with conjugated heat transfer and I would like to Plot the Nusselt Number with ParaView, however I don't know how to calculate it with OpenFOAM. I do can calculate the Nusselt Field in ParaView, but I can't Plot it over a line (That's my goal). At the beginning I downloaded the last version of ParaView because the version of OpenFOAM (sudo apt-get install paraviewopenfoam410) cannot use the "Calculator application" properly. So I downloaded the binary files from www.paraview.org. Now what I need is to plot the Nusselt Number over a line, but it does not let me do it with my Calculated Nusselt. |
June 8, 2014, 13:40 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Tom,
I have no idea if you've managed to solve this issue already or not, but if you haven't, please provide more information, namely:
Best regards, Bruno
April 26, 2016, 09:34 |
finding Nusselt number in paraview
narayana vekamulla
Rep Power: 10 |
Good evening Bruno,
i dont have any idea how to calculate derivatives and integrations in paraview. If you know how to calculate Nusselt number and Mean Nusslet number? please let me know. Thanks |
April 26, 2016, 14:49 |
Tobias Holzmann
Rep Power: 51 |
As far as I know, the Nusselt number can only be calculated on the walls because of its definition:
The heat transfer coefficient could be calculated using the heat flux or heat : Due to the fact that there has to be an equilibrium of Cell-Center to Face-Center and Face-Center out to air or even another fluid / solid, So finally you know or and you can calculate . Then you simply can calculate the Nusselt number.
Keep foaming, Tobias Holzmann |
May 3, 2016, 13:58 |
#5 | |
Lisandro Maders
Rep Power: 13 |
I am new to ParaView, could you explain to me how to get the or values from Paraview? I have a cylinder and need to know the dissipated heat through its external surface. What I would imagine to do: take temperature value of face-center cell of external surface cells; take temperature of respective volume-center cell; calculate its difference corresponding to a gradient in relation to cell size; do this for all external cells areas (integrate it); muliply by conductivity; The problem is that I don't know how to do it with ParaView... :P Thank you! Regards, Lisandro Maders Last edited by Lisandro Maders; May 3, 2016 at 14:22. Reason: better explanation of what I want |
May 3, 2016, 17:42 |
#7 | |
Lisandro Maders
Rep Power: 13 |
Anyway, cheers! |
May 3, 2016, 17:56 |
#8 | |
Tobias Holzmann
Rep Power: 51 |
if you use the openfoam utilities, why you are asking? OpenFOAM have the ability that a lot of functions are already there (like the calculation of the gradient of the cell-center and boundary face-center). I do not know if you can do this using paraview (maybe there is some workaround but I do not know it).
May 3, 2016, 17:58 |
#9 |
Lisandro Maders
Rep Power: 13 |
Actually, I was really making mess with this. Long day and I was tired. There is no reason for not using foam utilities, I just forgot everything I learned for some hours haha. But thanks anyway, I could be still struggling with this
calculate, nusselt number, paraview 4.1 |
Please Help on advising me on Plotting of Mach Number Contour Plot with Tecplot 360 | chor kiat | Tecplot | 1 | June 26, 2017 12:42 |
Calculating a generic scalar for each cell, and plotting it in prostar. | Storm123 | STAR-CD | 0 | May 20, 2017 20:18 |
calculating n plotting moments coefficients | maperik | CFX | 2 | June 20, 2011 09:59 |
