Home > Forums > OpenFOAM Paraview & paraFoam
Segmentation Fault on start - pvserver using o/s rendering, remote on cluster
Old   June 8, 2014, 21:23
Post Segmentation Fault on start - pvserver using o/s rendering, remote on cluster
Christian Butcher
chrisb2244 is on a distinguished road
I have installed from source Mesa-10.1.3, QT-4.8.6, and ParaView-4.1.0, on a cluster which is accessed using password-less ssh connections. I can ssh between the nodes and that all seems to be fine.
When I start the pvserver (on the login node only, to try and simplify matters, although the same happens with the working nodes of the cluster, the connection is just a bit messier so I might be also getting that wrong), I use
 $>> pvserver --use-offscreen-rendering
and get output like this:
Waiting for client...
Connection URL: cs://tombo-login3.oist.jp:11111
Accepting connection(s): tombo-login3.oist.jp:11111
When I, on my local workstation, start paraview, and connect using the gui to the tombo-login3.oist.jp:11111, the local client complains about losing a connection, and a broken pipe, whilst the server prints:
Client connected.
[tombo-login3:04882] *** Process received signal ***
[tombo-login3:04882] Signal: Segmentation fault (11)
[tombo-login3:04882] Signal code: Address not mapped (1)
[tombo-login3:04882] Failing at address: (nil)
[tombo-login3:04882] [ 0] /lib64/libpthread.so.0() [0x3d2440f710]
[tombo-login3:04882] [ 1] /lib64/libc.so.6() [0x3d23c8ad96]
[tombo-login3:04882] [ 2] /lib64/libc.so.6() [0x3d23c75a10]
[tombo-login3:04882] [ 3] /lib64/libc.so.6(vsscanf+0x65) [0x3d23c699b5]
[tombo-login3:04882] [ 4] /lib64/libc.so.6(_IO_sscanf+0x88) [0x3d23c63a28]
[tombo-login3:04882] [ 5] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingOpenGL-pv4.1.so.1(_ZN25vtkOpenGLExtensionManager20ReadOpenGLExtensionsEv+0x160) [0x2b8fe10bc950]
[tombo-login3:04882] [ 6] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingOpenGL-pv4.1.so.1(_ZN25vtkOpenGLExtensionManager6UpdateEv+0x30) [0x2b8fe10bbe00]
[tombo-login3:04882] [ 7] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingOpenGL-pv4.1.so.1(_ZN25vtkOpenGLExtensionManager18ExtensionSupportedEPKc+0x17) [0x2b8fe10bbb47]
[tombo-login3:04882] [ 8] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingOpenGL-pv4.1.so.1(_ZN21vtkOpenGLRenderWindow17OpenGLInitContextEv+0x4a) [0x2b8fe10f6a1a]
[tombo-login3:04882] [ 9] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingOpenGL-pv4.1.so.1(_ZN21vtkOpenGLRenderWindow10OpenGLInitEv+0xd) [0x2b8fe10f41ed]
[tombo-login3:04882] [10] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingOpenGL-pv4.1.so.1(_ZN23vtkOSOpenGLRenderWindow5StartEv+0xd) [0x2b8fe117059d]
[tombo-login3:04882] [11] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingCore-pv4.1.so.1(_ZN15vtkRenderWindow14DoStereoRenderEv+0x16) [0x2b8fd07931d6]
[tombo-login3:04882] [12] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingCore-pv4.1.so.1(_ZN15vtkRenderWindow10DoFDRenderEv+0x36b) [0x2b8fd079375b]
[tombo-login3:04882] [13] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingCore-pv4.1.so.1(_ZN15vtkRenderWindow10DoAARenderEv+0x461) [0x2b8fd0794811]
[tombo-login3:04882] [14] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingCore-pv4.1.so.1(_ZN15vtkRenderWindow6RenderEv+0xcd) [0x2b8fd079388d]
[tombo-login3:04882] [15] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVClientServerCoreRendering-pv4.1.so.1(_ZN15vtkPVRenderView6RenderEbb+0x20e) [0x2b8fda632ebe]
[tombo-login3:04882] [16] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVClientServerCoreRendering-pv4.1.so.1(_ZN15vtkPVRenderView11StillRenderEv+0x3c) [0x2b8fda6320fc]
[tombo-login3:04882] [17] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerManagerApplication-pv4.1.so.1(_Z22vtkPVRenderViewCommandP26vtkClientServerInterpreterP13vtkObjectBasePKcRK21vtkClientServerStreamRS5_Pv+0x140f) [0x2b8fcf1c114f]
[tombo-login3:04882] [18] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkClientServer-pv4.1.so.1(_ZN26vtkClientServerInterpreter19CallCommandFunctionEPKcP13vtkObjectBaseS1_RK21vtkClientServerStreamRS4_+0x14c) [0x2b8fd296e72c]
[tombo-login3:04882] [19] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkClientServer-pv4.1.so.1(_ZN26vtkClientServerInterpreter20ProcessCommandInvokeERK21vtkClientServerStreami+0x192) [0x2b8fd2972192]
[tombo-login3:04882] [20] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkClientServer-pv4.1.so.1(_ZN26vtkClientServerInterpreter17ProcessOneMessageERK21vtkClientServerStreami+0x28e) [0x2b8fd29717ee]
[tombo-login3:04882] [21] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkClientServer-pv4.1.so.1(_ZN26vtkClientServerInterpreter13ProcessStreamERK21vtkClientServerStream+0x1d) [0x2b8fd29718dd]
[tombo-login3:04882] [22] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerImplementationCore-pv4.1.so.1(_ZN16vtkPVSessionCore21ExecuteStreamInternalERK21vtkClientServerStreamb+0x10c) [0x2b8fcfc9420c]
[tombo-login3:04882] [23] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerImplementationCore-pv4.1.so.1(_ZN16vtkPVSessionCore13ExecuteStreamEjRK21vtkClientServerStreamb+0x4c) [0x2b8fcfc90b7c]
[tombo-login3:04882] [24] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerImplementationCore-pv4.1.so.1(_ZN16vtkPVSessionBase13ExecuteStreamEjRK21vtkClientServerStreamb+0x42) [0x2b8fcfc8e6c2]
[tombo-login3:04882] [25] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerImplementationCore-pv4.1.so.1(_ZN18vtkPVSessionServer24OnClientServerMessageRMIEPvi+0x143) [0x2b8fcfc97533]
[tombo-login3:04882] [26] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkParallelCore-pv4.1.so.1(_ZN25vtkMultiProcessController10ProcessRMIEiPvii+0x168) [0x2b8fd3513108]
[tombo-login3:04882] [27] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkParallelCore-pv4.1.so.1(_ZN25vtkMultiProcessController11ProcessRMIsEii+0x101) [0x2b8fd35135b1]
[tombo-login3:04882] [28] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVClientServerCoreCore-pv4.1.so.1(_ZN26vtkTCPNetworkAccessManager21ProcessEventsInternalEmb+0x35e) [0x2b8fcff887be]
[tombo-login3:04882] [29] /imports/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/pvserver(main+0x21b) [0x401c4b]
[tombo-login3:04882] *** End of error message ***
Segmentation fault
My PATH and LD_LIBRARY_PATH are:
christian-butcher@tombo-login3:~$ echo $PATH
/home/c/christian-butcher/Tombo3_SL6.5/bin:/home/c/christian-butcher/Tombo3_SL6.5/QT-4.8.6/bin:/home/c/christian-butcher/OpenFOAM/christian-butcher-2.3.0/platforms/linux64GccDPOpt/bin:/home/c/christian-butcher/OpenFOAM/site/2.3.0/platforms/linux64GccDPOpt/bin:/home/c/christian-butcher/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin:/home/c/christian-butcher/OpenFOAM/OpenFOAM-2.3.0/bin:/home/c/christian-butcher/OpenFOAM/OpenFOAM-2.3.0/wmake:/opt/mpi/gnu/openmpi-1.6.3/bin:/gridware/sge/bin/lx24-amd64:/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin
christian-butcher@tombo-login3:~$ echo $LD_LIBRARY_PATH
/home/c/christian-butcher/Tombo3_SL6.5/lib:/home/c/christian-butcher/Tombo3_SL6.5/QT-4.8.6/lib/:/home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/:/home/c/christian-butcher/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/openmpi-system:/home/c/christian-butcher/OpenFOAM/ThirdParty-2.3.0/platforms/linux64GccDPOpt/lib/openmpi-system:/opt/mpi/gnu/openmpi-1.6.3/lib:/home/c/christian-butcher/OpenFOAM/christian-butcher-2.3.0/platforms/linux64GccDPOpt/lib:/home/c/christian-butcher/OpenFOAM/site/2.3.0/platforms/linux64GccDPOpt/lib:/home/c/christian-butcher/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib:/home/c/christian-butcher/OpenFOAM/ThirdParty-2.3.0/platforms/linux64GccDPOpt/lib:/home/c/christian-butcher/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/dummy
I'm unsure where I've gone wrong (although I suspect it might be in the compilation of either QT or Mesa).
If anyone could advise, I'd very much appreciate it.
If any further information is needed, please let me know.
Christian
chrisb2244 is offline   Reply With Quote
Old   June 8, 2014, 21:25
Default ldd for pvserver (too long a message)
Christian Butcher
christian-butcher@tombo-login3:~$ ldd /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/pvserver
	linux-vdso.so.1 =>  (0x00007ffff0219000)
	libvtkPVServerManagerApplication-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerManagerApplication-pv4.1.so.1 (0x00002b5e6108d000)
	libvtkUtilitiesPythonInitializer-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkUtilitiesPythonInitializer-pv4.1.so.1 (0x00002b5e61d86000)
	libvtkPVServerManagerCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerManagerCore-pv4.1.so.1 (0x00002b5e61f87000)
	libvtkPVServerImplementationCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerImplementationCore-pv4.1.so.1 (0x00002b5e622e5000)
	libvtkPVClientServerCoreCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVClientServerCoreCore-pv4.1.so.1 (0x00002b5e6258c000)
	libvtkFiltersParallel-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersParallel-pv4.1.so.1 (0x00002b5e62855000)
	libvtkFiltersModeling-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersModeling-pv4.1.so.1 (0x00002b5e62ac5000)
	libvtkRenderingCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingCore-pv4.1.so.1 (0x00002b5e62d12000)
	libvtkFiltersExtraction-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersExtraction-pv4.1.so.1 (0x00002b5e630bb000)
	libvtkFiltersStatistics-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersStatistics-pv4.1.so.1 (0x00002b5e63387000)
	libvtkImagingFourier-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkImagingFourier-pv4.1.so.1 (0x00002b5e635f2000)
	libvtkImagingCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkImagingCore-pv4.1.so.1 (0x00002b5e63813000)
	libvtkalglib-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkalglib-pv4.1.so.1 (0x00002b5e63bb1000)
	libvtkFiltersGeometry-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersGeometry-pv4.1.so.1 (0x00002b5e63ddf000)
	libvtkFiltersSources-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersSources-pv4.1.so.1 (0x00002b5e64043000)
	libvtkFiltersGeneral-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersGeneral-pv4.1.so.1 (0x00002b5e642bd000)
	libvtkCommonComputationalGeometry-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonComputationalGeometry-pv4.1.so.1 (0x00002b5e64767000)
	libvtkFiltersProgrammable-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersProgrammable-pv4.1.so.1 (0x00002b5e64987000)
	libvtkPVVTKExtensionsCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVVTKExtensionsCore-pv4.1.so.1 (0x00002b5e64b92000)
	libvtkPVCommon-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVCommon-pv4.1.so.1 (0x00002b5e64dd9000)
	libvtkClientServer-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkClientServer-pv4.1.so.1 (0x00002b5e64ffa000)
	libvtkIOXMLParser-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOXMLParser-pv4.1.so.1 (0x00002b5e65223000)
	libvtkFiltersCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersCore-pv4.1.so.1 (0x00002b5e65439000)
	libvtkParallelMPI-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkParallelMPI-pv4.1.so.1 (0x00002b5e65970000)
	libvtkParallelCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkParallelCore-pv4.1.so.1 (0x00002b5e65b8f000)
	libvtkIOLegacy-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOLegacy-pv4.1.so.1 (0x00002b5e65dd7000)
	libvtkIOCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOCore-pv4.1.so.1 (0x00002b5e66051000)
	libvtkCommonExecutionModel-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonExecutionModel-pv4.1.so.1 (0x00002b5e662be000)
	libvtkCommonDataModel-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonDataModel-pv4.1.so.1 (0x00002b5e6654e000)
	libvtkCommonSystem-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonSystem-pv4.1.so.1 (0x00002b5e66a67000)
	libvtkCommonTransforms-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonTransforms-pv4.1.so.1 (0x00002b5e66c7a000)
	libvtkCommonMisc-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonMisc-pv4.1.so.1 (0x00002b5e66ea4000)
	libvtkCommonMath-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonMath-pv4.1.so.1 (0x00002b5e670b6000)
	libvtkPythonInterpreter-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPythonInterpreter-pv4.1.so.1 (0x00002b5e672d4000)
	libprotobuf.so => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libprotobuf.so (0x00002b5e674dd000)
	libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003d24400000)
	libz.so.1 => /lib64/libz.so.1 (0x0000003d24800000)
	libvtkWrappingPython27Core-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkWrappingPython27Core-pv4.1.so.1 (0x00002b5e677d7000)
	libvtkCommonCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonCore-pv4.1.so.1 (0x00002b5e67a05000)
	libpython2.7.so.1.0 => /home/c/christian-butcher/Tombo3_SL6.5/lib/libpython2.7.so.1.0 (0x00002b5e67f83000)
	libvtksys-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtksys-pv4.1.so.1 (0x00002b5e68363000)
	libdl.so.2 => /lib64/libdl.so.2 (0x0000003d24000000)
	libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x000000301d400000)
	libm.so.6 => /lib64/libm.so.6 (0x0000003d23800000)
	libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x000000301d800000)
	libc.so.6 => /lib64/libc.so.6 (0x0000003d23c00000)
	libvtkIOInfovis-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOInfovis-pv4.1.so.1 (0x00002b5e685a4000)
	libvtkIOAMR-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOAMR-pv4.1.so.1 (0x00002b5e687f1000)
	libvtkFiltersParallelImaging-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersParallelImaging-pv4.1.so.1 (0x00002b5e68a22000)
	libvtkFiltersImaging-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersImaging-pv4.1.so.1 (0x00002b5e68c36000)
	libvtkFiltersParallelFlowPaths-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersParallelFlowPaths-pv4.1.so.1 (0x00002b5e68e4b000)
	libvtkFiltersTexture-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersTexture-pv4.1.so.1 (0x00002b5e69075000)
	libvtkFiltersVerdict-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersVerdict-pv4.1.so.1 (0x00002b5e69289000)
	libvtkverdict-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkverdict-pv4.1.so.1 (0x00002b5e694a0000)
	libvtkInteractionImage-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkInteractionImage-pv4.1.so.1 (0x00002b5e696d2000)
	libvtkIOPLY-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOPLY-pv4.1.so.1 (0x00002b5e698e3000)
	libvtkIOParallelLSDyna-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOParallelLSDyna-pv4.1.so.1 (0x00002b5e69af8000)
	libvtkIOLSDyna-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOLSDyna-pv4.1.so.1 (0x00002b5e69d01000)
	libvtkIOParallelNetCDF-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOParallelNetCDF-pv4.1.so.1 (0x00002b5e69f51000)
	libvtkIOVPIC-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOVPIC-pv4.1.so.1 (0x00002b5e6a169000)
	libvtkVPIC-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkVPIC-pv4.1.so.1 (0x00002b5e6a372000)
	libmpi_cxx.so.1 => /opt/mpi/gnu/openmpi-1.6.3/lib/libmpi_cxx.so.1 (0x00002b5e6a599000)
	libvtkIOVisItBridge-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOVisItBridge-pv4.1.so.1 (0x00002b5e6a7b4000)
	libvtkFiltersFlowPaths-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersFlowPaths-pv4.1.so.1 (0x00002b5e6adc0000)
	libvtkIOXdmf2-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOXdmf2-pv4.1.so.1 (0x00002b5e6b014000)
	libvtkImagingMorphological-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkImagingMorphological-pv4.1.so.1 (0x00002b5e6b247000)
	libvtkRenderingLOD-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingLOD-pv4.1.so.1 (0x00002b5e6b4ac000)
	libvtkParaViewWebCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkParaViewWebCore-pv4.1.so.1 (0x00002b5e6b6b7000)
	libvtkPVServerManagerDefault-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerManagerDefault-pv4.1.so.1 (0x00002b5e6b8c5000)
	libvtkTestingRendering-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkTestingRendering-pv4.1.so.1 (0x00002b5e6bb03000)
	libvtkIOFFMPEG-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOFFMPEG-pv4.1.so.1 (0x00002b5e6bd14000)
	libvtkIOMovie-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOMovie-pv4.1.so.1 (0x00002b5e6bf1c000)
	libvtkoggtheora-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkoggtheora-pv4.1.so.1 (0x00002b5e6c125000)
	libvtkPVServerImplementationDefault-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerImplementationDefault-pv4.1.so.1 (0x00002b5e6c367000)
	libvtkPVClientServerCoreDefault-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVClientServerCoreDefault-pv4.1.so.1 (0x00002b5e6c56e000)
	libvtkPVServerManagerRendering-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerManagerRendering-pv4.1.so.1 (0x00002b5e6c794000)
	libvtkPVServerImplementationRendering-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVServerImplementationRendering-pv4.1.so.1 (0x00002b5e6ca08000)
	libvtkPVClientServerCoreRendering-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVClientServerCoreRendering-pv4.1.so.1 (0x00002b5e6cc1b000)
	libvtkRenderingVolumeOpenGL-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingVolumeOpenGL-pv4.1.so.1 (0x00002b5e6cf27000)
	libvtkViewsContext2D-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkViewsContext2D-pv4.1.so.1 (0x00002b5e6d1ae000)
	libvtkViewsCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkViewsCore-pv4.1.so.1 (0x00002b5e6d3b8000)
	libvtkDomainsChemistry-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkDomainsChemistry-pv4.1.so.1 (0x00002b5e6d5d6000)
	libvtkPVVTKExtensionsDefault-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVVTKExtensionsDefault-pv4.1.so.1 (0x00002b5e6d803000)
	libvtkFiltersParallelStatistics-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersParallelStatistics-pv4.1.so.1 (0x00002b5e6dc67000)
	libvtkIOEnSight-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOEnSight-pv4.1.so.1 (0x00002b5e6de8f000)
	libvtkIOImport-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOImport-pv4.1.so.1 (0x00002b5e6e0f9000)
	libvtkIOMPIImage-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOMPIImage-pv4.1.so.1 (0x00002b5e6e31e000)
	libvtkIOParallel-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOParallel-pv4.1.so.1 (0x00002b5e6e53c000)
	libvtkIONetCDF-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIONetCDF-pv4.1.so.1 (0x00002b5e6e783000)
	libvtkIOParallelExodus-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOParallelExodus-pv4.1.so.1 (0x00002b5e6e9d3000)
	libvtkIOExodus-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOExodus-pv4.1.so.1 (0x00002b5e6ebf6000)
	libvtkPVVTKExtensionsRendering-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkPVVTKExtensionsRendering-pv4.1.so.1 (0x00002b5e6ee9e000)
	libvtkChartsCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkChartsCore-pv4.1.so.1 (0x00002b5e6f1da000)
	libvtkCommonColor-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkCommonColor-pv4.1.so.1 (0x00002b5e6f509000)
	libvtkInfovisCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkInfovisCore-pv4.1.so.1 (0x00002b5e6f722000)
	libvtkRenderingFreeTypeOpenGL-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingFreeTypeOpenGL-pv4.1.so.1 (0x00002b5e6f9db000)
	libvtkFiltersGeneric-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersGeneric-pv4.1.so.1 (0x00002b5e6fbe6000)
	libvtkFiltersHyperTree-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersHyperTree-pv4.1.so.1 (0x00002b5e6fe0c000)
	libvtkFiltersParallelMPI-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersParallelMPI-pv4.1.so.1 (0x00002b5e7003e000)
	libvtkRenderingParallel-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingParallel-pv4.1.so.1 (0x00002b5e70257000)
	libvtkRenderingMatplotlib-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingMatplotlib-pv4.1.so.1 (0x00002b5e70489000)
	libvtkRenderingParallelLIC-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingParallelLIC-pv4.1.so.1 (0x00002b5e70694000)
	libvtkRenderingLIC-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingLIC-pv4.1.so.1 (0x00002b5e7093d000)
	libvtkIOXML-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOXML-pv4.1.so.1 (0x00002b5e70bed000)
	libvtkIOGeometry-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOGeometry-pv4.1.so.1 (0x00002b5e70ebc000)
	libIceTMPI.so => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libIceTMPI.so (0x00002b5e711c7000)
	libmpi.so.1 => /opt/mpi/gnu/openmpi-1.6.3/lib/libmpi.so.1 (0x00002b5e713ca000)
	librt.so.1 => /lib64/librt.so.1 (0x0000003d24c00000)
	libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003d33400000)
	libutil.so.1 => /lib64/libutil.so.1 (0x0000003d36a00000)
	libIceTGL.so => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libIceTGL.so (0x00002b5e7176b000)
	libIceTCore.so => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libIceTCore.so (0x00002b5e71970000)
	libvtkNetCDF_cxx-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkNetCDF_cxx-pv4.1.so.1 (0x00002b5e71b92000)
	libvtkNetCDF-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkNetCDF-pv4.1.so.1 (0x00002b5e71db1000)
Old   June 8, 2014, 21:26
Default The rest of the ldd
Christian Butcher
	libvtkhdf5_hl-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkhdf5_hl-pv4.1.so.1 (0x00002b5e720b5000)
	libvtkhdf5-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkhdf5-pv4.1.so.1 (0x00002b5e722e2000)
	libvtkRenderingVolumeAMR-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingVolumeAMR-pv4.1.so.1 (0x00002b5e72796000)
	libvtkFiltersAMR-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersAMR-pv4.1.so.1 (0x00002b5e729a1000)
	libvtkWebCore-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkWebCore-pv4.1.so.1 (0x00002b5e72bc6000)
	libvtkWebGLExporter-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkWebGLExporter-pv4.1.so.1 (0x00002b5e72de0000)
	libvtkIOExport-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOExport-pv4.1.so.1 (0x00002b5e7300d000)
	libvtkRenderingGL2PS-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingGL2PS-pv4.1.so.1 (0x00002b5e7325b000)
	libvtkRenderingContext2D-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingContext2D-pv4.1.so.1 (0x00002b5e7346e000)
	libvtkRenderingOpenGL-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingOpenGL-pv4.1.so.1 (0x00002b5e736b4000)
	libGLU.so.1 => /usr/lib64/libGLU.so.1 (0x0000003dbd000000)
	libSM.so.6 => /usr/lib64/libSM.so.6 (0x0000003d2cc00000)
	libICE.so.6 => /usr/lib64/libICE.so.6 (0x0000003d2c800000)
	libX11.so.6 => /usr/lib64/libX11.so.6 (0x0000003d26400000)
	libXext.so.6 => /usr/lib64/libXext.so.6 (0x0000003d27000000)
	libvtkRenderingLabel-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingLabel-pv4.1.so.1 (0x00002b5e73a58000)
	libvtkInteractionWidgets-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkInteractionWidgets-pv4.1.so.1 (0x00002b5e73cdb000)
	libvtkImagingHybrid-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkImagingHybrid-pv4.1.so.1 (0x00002b5e740a4000)
	libvtkIOImage-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkIOImage-pv4.1.so.1 (0x00002b5e742ee000)
	libvtkRenderingVolume-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingVolume-pv4.1.so.1 (0x00002b5e74601000)
	libvtkRenderingAnnotation-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingAnnotation-pv4.1.so.1 (0x00002b5e74daa000)
	libvtkRenderingFreeType-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkRenderingFreeType-pv4.1.so.1 (0x00002b5e7505f000)
	libvtkftgl-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkftgl-pv4.1.so.1 (0x00002b5e75311000)
	libGL.so.1 => /usr/lib64/libGL.so.1 (0x0000003d35e00000)
	libOSMesa.so.8 => /home/c/christian-butcher/Tombo3_SL6.5/lib/libOSMesa.so.8 (0x00002b5e7551c000)
	libvtkfreetype-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkfreetype-pv4.1.so.1 (0x00002b5e75e68000)
	libvtkzlib-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkzlib-pv4.1.so.1 (0x00002b5e760f4000)
	libvtkImagingColor-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkImagingColor-pv4.1.so.1 (0x00002b5e76309000)
	libvtkFiltersHybrid-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkFiltersHybrid-pv4.1.so.1 (0x00002b5e76544000)
	libvtkImagingGeneral-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkImagingGeneral-pv4.1.so.1 (0x00002b5e767f0000)
	libvtkImagingSources-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkImagingSources-pv4.1.so.1 (0x00002b5e76aad000)
	libvtkInteractionStyle-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkInteractionStyle-pv4.1.so.1 (0x00002b5e76ce5000)
	libvtkexpat-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkexpat-pv4.1.so.1 (0x00002b5e76f22000)
	/lib64/ld-linux-x86-64.so.2 (0x0000003d23400000)
	libvtklibxml2-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtklibxml2-pv4.1.so.1 (0x00002b5e7714b000)
	libvtkvisitcommon-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkvisitcommon-pv4.1.so.1 (0x00002b5e774b5000)
	libvtkavtdatabase_par-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkavtdatabase_par-pv4.1.so.1 (0x00002b5e77a19000)
	libvtkavtpipeline_par-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkavtpipeline_par-pv4.1.so.1 (0x00002b5e77ce8000)
	libvtkavtivp-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkavtivp-pv4.1.so.1 (0x00002b5e78059000)
	libvtkvisit_vtk-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkvisit_vtk-pv4.1.so.1 (0x00002b5e78273000)
	libvtkavtdbatts-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkavtdbatts-pv4.1.so.1 (0x00002b5e7852f000)
	libvtklightweight_visit_vtk-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtklightweight_visit_vtk-pv4.1.so.1 (0x00002b5e787b5000)
	libvtkavtmath-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkavtmath-pv4.1.so.1 (0x00002b5e78a16000)
	libvtkxdmf2-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkxdmf2-pv4.1.so.1 (0x00002b5e78c23000)
	libavformat.so.55 => /home/c/christian-butcher/Tombo3_SL6.5/lib/libavformat.so.55 (0x00002b5e78e86000)
	libavcodec.so.55 => /home/c/christian-butcher/Tombo3_SL6.5/lib/libavcodec.so.55 (0x00002b5e7921e000)
	libavutil.so.52 => /home/c/christian-butcher/Tombo3_SL6.5/lib/libavutil.so.52 (0x00002b5e7a527000)
	libswscale.so.2 => /home/c/christian-butcher/Tombo3_SL6.5/lib/libswscale.so.2 (0x00002b5e7a77a000)
	libvtkexoIIc-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkexoIIc-pv4.1.so.1 (0x00002b5e7a9fd000)
	libvtkjsoncpp-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkjsoncpp-pv4.1.so.1 (0x00002b5e7ac46000)
	libvtkgl2ps-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkgl2ps-pv4.1.so.1 (0x00002b5e7ae67000)
	libvtkpng-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkpng-pv4.1.so.1 (0x00002b5e7b082000)
	libuuid.so.1 => /lib64/libuuid.so.1 (0x0000003d2a800000)
	libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x0000003d26800000)
	libvtkjpeg-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkjpeg-pv4.1.so.1 (0x00002b5e7b2ab000)
	libvtktiff-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtktiff-pv4.1.so.1 (0x00002b5e7b4df000)
	libvtkmetaio-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkmetaio-pv4.1.so.1 (0x00002b5e7b73e000)
	libvtkDICOMParser-pv4.1.so.1 => /home/c/christian-butcher/Tombo3_SL6.5/lib/paraview-4.1/libvtkDICOMParser-pv4.1.so.1 (0x00002b5e7b9cc000)
	libglapi.so.0 => /usr/lib64/libglapi.so.0 (0x0000003d36200000)
	libXdamage.so.1 => /usr/lib64/libXdamage.so.1 (0x0000003d31600000)
	libXfixes.so.3 => /usr/lib64/libXfixes.so.3 (0x0000003d29800000)
	libX11-xcb.so.1 => /usr/lib64/libX11-xcb.so.1 (0x0000003d35a00000)
	libxcb-glx.so.0 => /usr/lib64/libxcb-glx.so.0 (0x0000003d35200000)
	libxcb-dri2.so.0 => /usr/lib64/libxcb-dri2.so.0 (0x0000003d36600000)
	libXxf86vm.so.1 => /usr/lib64/libXxf86vm.so.1 (0x0000003d34000000)
	libdrm.so.2 => /usr/lib64/libdrm.so.2 (0x0000003d35600000)
	libselinux.so.1 => /lib64/libselinux.so.1 (0x0000003d25400000)
	libtinfo.so.5 => /lib64/libtinfo.so.5 (0x0000003d31e00000)
	libLLVM-3.4.so => /home/c/christian-butcher/Tombo3_SL6.5/lib/libLLVM-3.4.so (0x00002b5e7bbe8000)
	libswresample.so.0 => /home/c/christian-butcher/Tombo3_SL6.5/lib/libswresample.so.0 (0x00002b5e7de8f000)
	libXau.so.6 => /usr/lib64/libXau.so.6 (0x0000003d26c00000)
Apologies for the multiple posts - apparently this is a long set of libraries and paths.
cluster, paraview 4.1.0, pvserver, segmentation fault
Thread Tools
Trackbacks are On
How to run Fluent in parallel on remote cluster? motorbean FLUENT 0 April 14, 2014 09:47
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
how to start parallel fluent in a cluster with remote login ztdep FLUENT 0 May 8, 2013 09:12
Please help cannot start lamboot hsieh OpenFOAM Installation 8 May 24, 2007 14:44
KIVA and Segmentation Fault Felix Main CFD Forum 2 January 18, 2006 02:24
