[OpenFOAM] paraview not taking columns as separate fields |
June 11, 2014, 05:18 |
starter
Rep Power: 15 |
Hi
I am trying paraview to read a csv file and applying Table to points filter on it. However even if my detect numeric columns and string delimiter is turned off, my data is read all in a single cell as Field 0. Original file has six columns x,y,z,U0,U1,U2. these are velocity vectors at any single point. What should I do so that data can be compiled in six fields or columns and then plot a velocity profile for single velocity value. I have read on forums that I have to apply a calculator and then glyph on it, however please guide how can I can make my csv file correct in the first instance so I may proceed to the next step. In the attached file, please change the extension to .csv as I did .txt to attach it. This forum does not support .csv format. Regards Imad |
June 12, 2014, 06:31 |
starter
Rep Power: 15 |
problem sorted out.
August 26, 2014, 22:33 |
How??
Ndong-Mefane Stephane Boris
Rep Power: 12 |
Is it ok to know how you solved your problem????
Stephane |
December 26, 2017, 11:57 |
Francisco Angel
Rep Power: 13 |
I had the same problem. Just try different conbinations of detect numeric columns, have headers, etc until you find one appropiate for your data. Still trying to get a good surface plot of the data though....
csv files, paraview |
Star-CD with ParaView | usker | STAR-CD | 3 | December 9, 2015 14:20 |
ParaView fills my RAM | Phicau | OpenFOAM Bugs | 4 | December 10, 2012 11:04 |
[OpenFOAM] Paraview in Prallel (server-client) | prapanj | ParaView | 11 | September 24, 2010 07:12 |
Missing fields in reconstructPar | flowris | OpenFOAM | 1 | July 9, 2010 02:48 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 09:15 |
