Home > Forums > OpenFOAM Paraview & paraFoam
ParaView shows bad cells, checkMesh doesn't seem to notice.
Old   August 15, 2014, 22:02
Question ParaView shows bad cells, checkMesh doesn't seem to notice.
CoolHand's Avatar
Ben
CoolHand is on a distinguished road
Hey OpenFOAMers,
So I've got this mesh. blockMesh runs without errors and checkMesh does not report any bad cells. Viewing the mesh from the outside or from the inside (Cull Front Face) the mesh looks good, but then if I take a clip to look at the interior volume cells I can see some uglyness (See third image attached). Any idea whats going on here?
checkMesh Log:
   Mesh stats
    faces:            2557500
    internal faces:   2506500
    cells:            844000
    faces per cell:   6
    boundary patches: 9
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     844000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    inlet               2400     2501     ok (non-closed singly connected)
    outlet              7200     7381     ok (non-closed singly connected)
    leftWall            9000     9196     ok (non-closed singly connected)
    rightWall           9000     9196     ok (non-closed singly connected)
    upperWall           7700     7836     ok (non-closed singly connected)
    lowerWall           5700     5875     ok (non-closed singly connected)
    cylWall             3200     3280     ok (non-closed singly connected)
    cylTop              2000     2041     ok (non-closed singly connected)
    trip                4800     4941     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.7 0 -0.3) (0.4 0.04 0.3)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-3.961e-18 -1.165e-14 4.242e-15) OK.
    Max cell openness = 2.453e-16 OK.
    Max aspect ratio = 319.2 OK.
    Minimum face area = 2.5e-07. Maximum face area = 0.000224.  Face         area magnitudes OK.
    Min volume = 7.556e-10. Max volume = 2.708e-07.  Total volume = 0.02634.  Cell volumes OK.
    Mesh non-orthogonality Max: 41.89 average: 7.464
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.7542 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
blockMeshDict: (Sorry about the weird spacing. It didn't copy & paste well.)
convertToMeters 0.1;
vertices
	(-0.25	  0		  0.25)	//0
	(0.25	  0 		0.25)	//1
	(0.25 	  0 		-0.25)	//2
	(-0.25	  0 		-0.25)	//3
	(-0.707	  0 		0.707)	//4
	(0.707 	  0 		0.707)	//5
	(0.707 	  0 		-0.707)	//6
	(-0.707 	  0 		-0.707)	//7
	(-1.414 	  0 		1.414)	//8
	(1.414	  0 		1.414)	//9
	(1.414 	  0 		-1.414)	//10
	(-1.414 	  0 		-1.414)	//11
	(-7 		  0 		3)		//12
	(-1.414 	  0 		3)		//13
	(1.414	  0 		3)		//14
	(4 		  0 		3)		//15
	(-7 		  0 		1.414)	//16
	(4 		  0 		1.414)	//17
	(-7 	  	  0 		-1.414)	//18
	(4 		  0 		-1.414)	//19
	(-7 		  0 		-3)		//20
	(-1.414 	  0 		-3)		//21
	(1.414 	  0 		-3)		//22
	(4 		  0 		-3)		//23
	(-0.25	 0.02 	 	  0.25)		//24
	(0.25	 0.02 		  0.25)		//25
	(0.25 	 0.02 	         -0.25)	//26
	(-0.25	 0.02 	         -0.25)	//27
	(-0.707	 0.02 	        0.707)	//28
	(0.707  	 0.02 	         0.707)	//29
	(0.707 	 0.02 	        -0.707)	//30
	(-0.707 	 0.02 		-0.707)	//31
	(-1.414 	 0.02 		 1.414)	//32
	(1.414	 0.02 	         1.414)	//33
	(1.414 	 0.02 		-1.414)	//34
	(-1.414 	 0.02 		-1.414)	//35
	(-7 		   0.02		3)		//36
	(-1.414 	   0.02 		3)		//37
	(1.414	   0.02 		3)		//38
	(4 		   0.02 		3)		//39
	(-7 	   	   0.02 		1.414)	//40
	(4 		   0.02 		1.414)	//41
	(-7 		   0.02 		-1.414)	//42
	(4 		   0.02 		-1.414)	//43
	(-7 		   0.02 		-3)		//44
	(-1.414 	   0.02 		-3)		//45
	(1.414 	   0.02 		-3)		//46
	(4 		   0.02 		-3)		//47
	(-0.25	 	0.4		 0.25)		//48
	(0.25	        0.4 	         0.25)		  //49
	(0.25 		0.4 	        -0.25)		//50
	(-0.25		0.4 	        -0.25)		//51
	(-0.707	        0.4 	        0.707)		//52
	(0.707 	        0.4 		0.707)	//53
	(0.707 	        0.4 		-0.707)	//54
	(-0.707 	        0.4 	         -0.707)	//55
	(-1.414 	        0.4 		1.414)	//56
	(1.414		0.4 	         1.414)	//57
	(1.414 	        0.4 		-1.414)	//58
	(-1.414 	        0.4 		-1.414)	//59
	(-7 		        0.4		  3)		//60
	(-1.414 	        0.4 		3)		//61
	(1.414		0.4 		3)		//62
	(4 		        0.4 		3)		//63
	(-7 		        0.4 		1.414)	//64
	(4 		        0.4 		1.414)	//65
	(-7 		        0.4 		-1.414)	//66
	(4 		        0.4 		-1.414)	//67
	(-7 		       0.4 		-3)		//68
	(-1.414 	       0.4 		-3)		//69
	(1.414  	       0.4 		-3)		//70
	(4 		       0.4 		-3)		//71
blocks
    hex (4 5 29 28 8 9 33 32) 	    (20 40 20) simpleGrading (1 1 1)		//0
    hex (6 10 34 30 5 9 33 29)	    (20 40 20) simpleGrading (1 1 1)		//1
    hex (11 10 34 35 7 6 30 31) 	  (20 40 20) simpleGrading (1 1 1)		//2
    hex (11 7 31 35 8 4 28 32) 	    (20 40 20) simpleGrading (1 1 1)		//3
    hex (16 8 32 40 12 13 37 36) 	  (35 40 20) simpleGrading (1 1 1)		//4
    hex (8 9 33 32 13 14 38 37) 	  (20 40 20) simpleGrading (1 1 1)		//5
    hex (9 17 41 33 14 15 39 38) 	  (20 40 20) simpleGrading (1 1 1)		//6
    hex (18 11 35 42 16 8 32 40) 	  (35 40 20) simpleGrading (1 1 1)		//7
    hex (10 19 43 34 9 17 41 33) 	  (20 40 20) simpleGrading (1 1 1)		//8
    hex (20 21 45 44 18 11 35 42) 	(35 40 20) simpleGrading (1 1 1)		//9
    hex (21 22 46 45 11 10 34 35) 	(20 40 20) simpleGrading (1 1 1)		//10
    hex (22 23 47 46 10 19 43 34) 	(20 40 20) simpleGrading (1 1 1)		//11
    hex (27 26 50 51 24 25 49 48) 	(20 80 20) simpleGrading (1 10 1)		//12
    hex (24 25 49 48 28 29 53 52) 	(20 80 20) simpleGrading (1 10 1)		//13
    hex (26 30 54 50 25 29 53 49) 	(20 80 20) simpleGrading (1 10 1)		//14
    hex (31 30 54 55 27 26 50 51) 	(20 80 20) simpleGrading (1 10 1)		//15
    hex (31 27 51 55 28 24 48 52) 	(20 80 20) simpleGrading (1 10 1)		//16
    hex (28 29 53 52 32 33 57 56) 	(20 80 20) simpleGrading (1 10 1)		//17
    hex (30 34 58 54 29 33 57 53) 	(20 80 20) simpleGrading (1 10 1)		//18
    hex (35 34 58 59 31 30 54 55) 	(20 80 20) simpleGrading (1 10 1)		//19
    hex (35 31 55 59 32 28 52 56) 	(20 80 20) simpleGrading (1 10 1)		//20
    hex (40 32 56 64 36 37 61 60) 	(35 80 20) simpleGrading (1 10 1)		//21
    hex (32 33 57 56 37 38 62 61) 	(20 80 20) simpleGrading (1 10 1)		//22
    hex (33 41 65 57 38 39 63 62) 	(20 80 20) simpleGrading (1 10 1)		//23
    hex (42 35 59 66 40 32 56 64) 	(35 80 20) simpleGrading (1 10 1)		//24
    hex (34 43 67 58 33 41 65 57) 	(20 80 20) simpleGrading (1 10 1)		//25
    hex (44 45 69 68 42 35 59 66) 	(35 80 20) simpleGrading (1 10 1)		//26
    hex (45 46 70 69 35 34 58 59) 	(20 80 20) simpleGrading (1 10 1)		//27
    hex (46 47 71 70 34 43 67 58) 	(20 80 20) simpleGrading (1 10 1)		//28
edges
	arc 4 5  	  (0 	0 	1)
	arc 5 6  	  (1	0 	0)
	arc 6 7  	  (0 	0 	-1)
	arc 4 7  	  (-1	0 	0)
	arc 8 9  	  (0 	0 	2)
	arc 9 10   	(2 	0 	0)
	arc 10 11  	(0 	0 	-2)
	arc 8 11   	(-2 	0  0)
	arc 28 29  	(0 	0.02 	1)
	arc 29 30  	(1 	0.02 	0)
	arc 30 31  	(0 	0.02 	-1)
	arc 28 31 	(-1 0.02 	0)
	arc 32 33  	(0 	0.02 	2)
	arc 33 34   (2 	0.02 	0)
	arc 34 35  	(0 	0.02	-2)
	arc 32 35   	(-2 	0.02 	0)
	arc 52 53 	(0 	0.4 	1)
	arc 53 54  	(1	0.4 	0)
	arc 54 55  	(0 	0.4	-1)
	arc 52 55 	(-1	0.4 	0)
	arc 56 57  	(0 	0.4 	2)
	arc 57 58   (2 	0.4	  0)
	arc 58 59  	(0 	0.4 	-2)
	arc 56 59   (-2 0.4 	0)
boundary
    inlet
        type patch;
        faces
		(12 36 40 16)
		(16 40 42 18)
		(18 42 44 20)
    outlet
        type patch;
        faces
		(23 47 43 19)
		(19 43 41 17)
		(17 41 39 15)
		(47 71 67 43)
		(43 67 65 41)
		(41 65 63 39)
    leftWall
        type symmetryPlane;
        faces
		(20 44 45 21)
		(21 45 46 22)
		(22 46 47 23)
		(44 68 69 45)
		(45 69 70 46)
		(46 70 71 47)
    rightWall
        type symmetryPlane;
        faces
		(15 39 38 14)
		(14 38 37 13)
		(13 37 36 12)
		(39 63 62 38)
		(38 62 61 37)
		(37 61 60 36)
    upperWall
        type symmetryPlane;
        faces
		(61 56 64 60)
		(62 57 56 61)
		(63 65 57 62)
		(56 59 66 64)
		(65 67 58 57)
		(59 69 68 66)
		(58 70 69 59)
		(67 71 70 58)
		(57 53 52 56)
		(57 58 54 53)
		(54 58 59 55)
		(52 55 59 56)
		(53 49 48 52)
		(53 54 50 49)
		(50 54 55 51)
		(48 51 55 52)
		(49 50 51 48)
    lowerWall
        type wall;
        faces
		(12 16 8 13)
		(13 8 9 14)
		(14 9 17 15)
		(16 18 11 8)
		(9 10 19 17)
		(18 20 21 11)
		(11 21 22 10)
		(10 22 23 19)
		(8 4 5 9)
		(5 6 10 9)
		(7 11 10 6)
		(8 11 7 4)
    cylWall
        type wall;
        faces
		(6 30 31 7)
		(5 29 30 6)
		(5 29 28 4)
		(7 31 28 4)
    cylTop
        type wall;
        faces
		(28 24 25 29)
		(25 26 30 29)
		(27 31 30 26)
		(28 31 27 24)
		(24 27 26 25)
     trip
        type wall;
        faces
		(36 60 64 40)
		(40 64 66 42)
		(42 66 68 44)
mergePatchPairs
CoolHand is offline   Reply With Quote
Old   August 16, 2014, 05:31
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Ben,
Two hints:
  1. Use the filter Extract Cells by Region, because this filter will preserve the cell structure. Clip and Slice filters will strictly need to tessellate/triangulate the mesh, which is why you got some weird triangles appearing in some places.
  2. Use the polyhedron option (i.e., to not decompose polyhedrons). foamToVTK also has this option, namely "-poly". This will avoid the decomposition of polyhedral cells and make it easier to diagnose the mesh. Problem is that the Slice and Clip filters can later on give you problems on more complex cells, which they are not able to decompose and can result in a crash.
edit: I've now added this to the FAQ, with more details: http://openfoamwiki.net/index.php/FA...is_in_ParaView
Best regards,
Bruno
Old   August 21, 2014, 15:58
CoolHand's Avatar
Ben
Thanks for your reply. I did that and it just didn't show those cells leaving those volumes empty.
My mesh was defined with the center at (0 0 0) so I moved all my points into the positive domain (inlet left corner at (0 0 0) and the bad cells went away. Not really sure why but it worked.
blockmesh, checkmesh
Thread Tools
Trackbacks are On
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
How to delete cells in OF based on CheckMesh? AndTen OpenFOAM Meshing & Mesh Conversion 13 June 24, 2015 04:09
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
how to deal with bad quality cells? phsieh2005 OpenFOAM 3 July 20, 2011 09:35
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
