[OpenFOAM] Is This A bug for Paraview 4.1.0 64bit |
September 4, 2014, 14:32 |
Yuanming Yu
Rep Power: 11 |
When I practiced vector plot in the OpenFoam lid-driven tutorial, I found there is no colored by velocity in display panel, only have colored by p, Glyphvector, cellNormals and Solid color. my paraview version is 4.4.0 64bit, is there something I have missed or it is a bug in Paraview? Is there anyone having the same problem? Thanks. |
September 5, 2014, 10:24 |
Laurent Fitschy
Rep Power: 14 |
Glyphvector contains the data used to draw the glyph. So, if you made your glyph from velocity vector, glyphvector is velocity vector. Regards, Laurent. |
September 5, 2014, 12:40 |
About color by velocity
Yuanming Yu
Rep Power: 11 |
Hello, GDTech,
Thank you for the reply. I think the GlyphVector is same as velocity U in this case. |
December 26, 2018, 04:20 |
Similar problem in ParaView 5.6.0
Reine Granström
Rep Power: 16 |
I have a similar problem in ParaView 5.6.0. For a Glyph, I have not figured out how to color the vectors by velocity magnitude. I first create a Slice that I can color either by velocity or pressure. When I create a Glyph based on this Slice, the available Coloring options for the Glyph are:
Can someone please point out what I am missing here? BR, Reine |
December 27, 2018, 12:04 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I don't have ParaView 5.6 at hand yet, but my guess is that you haven't checked all of the existing Glyph settings that exist.
In version 5.4 there are options on which scale field to use and if the data is mapped or not... Here is an example of how to select the U cell data field for the glyphs: Notice under "Active Attributes" the "Vectors" selection of the correct field.
December 27, 2018, 12:58 |
Details on the settings in 5.6
#6 | |
Reine Granström
Rep Power: 16 |
As in your example, I set "Glyph Type" to "Arrow". For "Orientation Array" I select the U cell (or point) data field. The vector arrows shown are as expected. If I change the "Scale Array" to "U", "p" or "No scale array", the arrows are scaled as expected. But for "Coloring", only the "p" point data field is available (as well as "Solid Color", "vtkCompositeIndex", "CasePath" and "ctkBlockColors (partial)" as I wrote in my previous post). I can not see any other obvious settings that would affect what data fields are available under "Coloring". I should also mention that I am running ParaView on MacOS Mojave. BR, Reine |
December 27, 2018, 15:33 |
Bruno Santos
Rep Power: 128 |
Quick answer: Wow... I was not expecting this... I've gotten ParaView 5.6.0 from paraview.org and indeed the vector fields are missing... they were simply filtered out, as well as the "glyphVector" entry that used to be there for Glyphs...
The workaround is to use a Calculator filter in the middle, that calculates the "mag(U)" field as point data: Then since it's then a point data scalar field, the field "Result" as shown above will appear in the "Coloring" options for the Glyph. If you forget to add the calculator after you've already added the Glyph entry, you can still add the calculator to the slice or any other entry, then right-click on the Glyph entry and choose to "Change Input..." Given that this is either a potential bug or a feature, you may want to ask about this at the Development sub-forum at ParaView's Discourse server: https://discourse.paraview.org/c/development - because I don't know if this is a ParaView bug/feature or if VTK (the main library ParaView depends on) is to blame here... |
December 27, 2018, 16:02 |
#8 | ||
Reine Granström
Rep Power: 16 |
March 29, 2020, 20:53 |
#9 |
Jose Rey
Rep Power: 17 |
I am using Paraview 5.8 now and have encountered the issue. Any resolution from them ? The calculate filter is a good patch solution in the meantime.
April 17, 2020, 17:36 |
Paraview 5.6.0 64-bit won't display Velocity Vectors
#10 |
John
Rep Power: 12 |
I suppose I should call them Glyphs now. Anyhow, running XUbuntu 18.04, 64bit (a LTS) with ParaView 5.6.0. Actually it's ParaFoam but I think the app is pretty much the same thing.
I encountered the error in that Velocity Vectors cannot be colored with Velocity: only with Pressure, [also vtk Composite Index, CasePath, vtk BlockColors, and of course Solid Color]. I can display countours of Velocity so I guess this means the data set is loaded. Wyldkat provides a workaround to use a Calulator filter in the middle. I've tried this and the Calculator Results still are not displayable. I'll attach a screenshot: For the Calculator I tried using the U as a Result accoring to the Scalers: Attrib. type: point data Result: sqrt(U_X^2+U_Y^2+U_Z^2) since I really have a 2-D model I also tried Result: sqrt(U_X^2+U_Y^2) Neither worked. I also downloaded the ParaView 5.8 but I notice that a user here states that it has the exact same problem so I haven't fooled with it yet. |
May 5, 2020, 22:13 |
Vectors are missing in ParaView - by design
#11 |
Alan
Interesting thread. A bit of background, then what is happening, then how to solve it.
ParaView has a design philosopy that we will attempt to never do something hidden or under the covers. There are three examples I found in this case. We won't magically convert cells to points, or points to cells. (Not sure what OpenFOAM calls these - Cells are Elements, Points are Nodes.) Another example is we will never create vector magnitudes from vectors. You have to do this manually, or tell ParaView to override default behavior. I believe that the root cause of the issue is that ParaView wants a point for Glyphs. Further, I believe it isn't passing cells through the Glyph filter, glyphs which are placed at points, not cells. In the cases where you do have the correct data, i.e., point vectors, ParaView doesn't have magnitudes. Note that one case where ParaView will make the conversion from vectors to magnitudes is when you want to color by a variable. How do we work around these issues? Let me give you the manual methods, then the shortcut (that hides what is going on.). If you have cells and need points (such as contour filter), run the Cell Data to Point Data filter. Point Data to Cell Data works in reverse. Note that default won't pass through the variables coming into this filter, but there is an option to do so. If you need magnitudes, run the Calculator filter, and mag(vector_name). That is 90% of the cases, you get the idea. Alternatively, there's a setting to turn on automatic conversions. It is Edit/ Settings/ AutoConvert Properties. Note that the tutorials are online, and much of this is covered. In Paraview, go Help/ Sandia National Labs Tutorials. I tried voodooing up an example, but couldn't get PV to fail. Anyway, I hope that adds some clarity. |
May 5, 2020, 22:35 |
#12 | |
John
Rep Power: 12 |
There are continuing comments by more knowledgeable users following mine and there may be some sort of bug. Here is the link (my name there is Julius Nepos as I tired of Gallienus): https://discourse.paraview.org/t/vel...?u=juliusnepos |
Display Modes | |
mapFields major bug | alchem | OpenFOAM Bugs | 14 | September 15, 2023 13:48 |
Bug in Workbench CFX | Pierre1 | CFX | 6 | August 2, 2017 01:18 |
[Helyx OS] Installing HelyxOS on 32 and 64bit Linux Distributions | wyldckat | OpenFOAM Community Contributions | 16 | December 23, 2016 07:37 |
Linux+CFD: is 64bit really a need? | CAVT | Hardware | 2 | August 27, 2010 18:12 |
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 | sponiar | OpenFOAM Running, Solving & CFD | 3 | February 26, 2008 07:31 |
