September 13, 2015, 08:16 |
periodic visualization in paraview
mohamed mohsen
Rep Power: 13 |
hello,
I'm solving a 10 degrees sector with periodic boundary conditions. I need to view the solution in the entire 360 degrees. Any help about periodic viewing in paraview inducing linear and rotational periodics. Thanks in advance |
September 15, 2015, 01:48 |
Mikko
Rep Power: 12 |
Hi mohamed,
Unfortunately, there is no native filter which can do this for you. However, you can play with transform filter. Here is a example script how to build the full 360 view from 10 degrees sectors (axis in z-direction) with Python Shell: Code:
source = GetActiveSource() t = transforms = [] for i in range(0,360,10): t=Transform(source) t.Transform.Rotate = [0,0,i] transforms.append(t) group = GroupDatasets() group.Input = transforms -Mikko |
September 15, 2015, 09:06 |
mohamed mohsen
Rep Power: 13 |
Thank you Mikko .. how can i load the source?
September 15, 2015, 09:51 |
Mikko
Rep Power: 12 |
After the first line of my script the source points to your active source in Paraview which should be the 10 degrees sector that you have opened before.
For completeness, here are all the steps: 1. Open the file with 10 degrees sector 2. Open the Python Shell inside Paraview (Tools->Python Shell) 3. Copy-Paste the script in my previous message to the shell Now the last filter in your Pipeline Browser (GroupDatasets) should have the full 360 degrees. |
September 19, 2015, 06:06 |
Mikko
Rep Power: 12 |
The latest ParaView 4.4 supports this, look at http://www.kitware.com/blog/home/post/906.
September 21, 2015, 05:08 |
mohamed mohsen
Rep Power: 13 |
thank you .. it opened a window for browsing for a python script?!
[OpenFOAM] Visualization of a 3D Flow field (paraview) | Chris123 | ParaView | 2 | November 27, 2018 08:51 |
[Other] Mesh quality visualization in paraview | Lieven | OpenFOAM Meshing & Mesh Conversion | 3 | June 20, 2018 19:03 |
[ICEM] Multizone periodic fails | herudae | ANSYS Meshing & Geometry | 2 | April 1, 2013 06:46 |
Visualization of Secondary Flow with ParaView | idrama | OpenFOAM | 2 | May 12, 2012 13:37 |
OpenFoam 2.0 hopper case visualization with Paraview | amscosta | OpenFOAM | 11 | September 15, 2011 02:44 |
