Error reading variable velocity (0/U.air)
Hi to everybody,
sometime, when I use a variable speed like this (in 0/U.air file): Code:
boundaryField Code:
ERROR: In /home/kitware/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 Can someone suggest a solution? Many thanks Piero |
It is not paraview and vectors. It is native paraview OpenFOAM reader and uniformFixedValue (table). So either you ignore error for 0 time (first save will just write value in file, which paraview reads quite successfully), or use OpenFOAM file reader (i.e. compile plugin, use OpenFOAM extension). |
I tried you first suggestion (to ignore time 0 errors), but it doesn't work: in fact, also the second time-step is written as the first, and Paraview 4.3.1 reports the same (=previous) error. The second time step 0.002/U.air is written as quoted: Code:
internalField nonuniform List<vector> About you second suggestion (compile plugin, use OpenFOAM extension), I have no time in this moment, by I will do a.s.a.p. Thank you for your help. |
again . . .
:cool: Well, this is my actual workaround: - reconstructPar (if run was parallelized) - foamToEnsight -nodeValues At this point, paraView reads perfectly Ensight case Thanks of your interest Piero |
