[OpenFOAM] ParaView Plotting: Why are some Filters in the Alphabetical list greyed out? |
August 5, 2015, 04:15 |
ArielJ
Rep Power: 10 |
Hi there,
Have to start this post again saying I am brand brand new to OpenFOAM (3 days in!) and I am trying to follow some basic tutorials but am having some issues with ParaView that I don't understand. First of all, when trying to plot another day, the tutorial instructed using "Plot Over Line" (for Couette flow problem), and it worked fine. However, now I'm trying to do the same again as well as follow instructions for another tutorial and now either one of two things happens: 1) "Plot over line" option is not even available on the list or 2) "Plot over line" is greyed out and not a possible option. I can't find any explanation for this as it seems that this filter option is the most basic and all tutorials say to use it (although do not give advice if the option is not available). I think this might have something to do with the installation but I'm not sure how? I follow the instructions at this link: https://openfoamwiki.net/index.php/I...OpenFOAM-2.3.1 for Ubuntu 12.04 to install OpenFOAM and ParaView. Thanks in advance for any advice! |
August 10, 2015, 09:21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: When filters are greyed out, usually means that they cannot be applied to the currently select item on the "Pipeline Browser". My guess is that you either did not have a valid item selected or simply no item was selected.
Some reading material:
May 18, 2016, 15:24 |
Lee
Rep Power: 10 |
Hi Ariel,
Did you figure out how to solve this problem? I am not struggling in the same problem as yours. The ''Plot over Line'' command is either not available in the list or is greyed out after I successfully used it once. Best Regards, Lee |
August 23, 2017, 13:30 |
Norbert
Hi everyone,
if they are greyed means they can't be applied to the case. For me it was enough to click on the case (split the window in two and click on the one under process). hope it helps have a nice day Kudzey |
greyed-out, openfoam 2.3.1, paraview 4.1.0, ubuntu 12.04 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[General] Equivalent C++ code for applied filters in Paraview | Sandbad | ParaView | 0 | January 12, 2018 20:14 |
[General] Plotting solution vector from Matlab in Paraview | crg123 | ParaView | 0 | November 20, 2016 12:19 |
[OpenFOAM] Calculating and Plotting Nusselt Number with ParaView | RTom | ParaView | 8 | May 3, 2016 17:58 |
[OpenFOAM] paraFoam filters greyed out | open | ParaView | 1 | April 19, 2016 05:12 |
