Home > Forums > OpenFOAM Paraview & paraFoam
paraview parafoam segmentation fault (core dumped)
Like Tree2Likes
  • 2 Post By RicardoLB
Old   October 29, 2015, 09:46
Unhappy paraview parafoam segmentation fault (core dumped)
Ricardo Lopez
RicardoLB is on a distinguished road
Hey all!
I was working until a couple of hours ago with OpenFOAM and paraview/paraFoam, until I got a "Segmentation fault (core dumped)" error... Out of the blue! I have different versions of OF (2.2.2, 2.3.0 and 2.3.1) installed, and paraview/paraFoam crashes with versions 2.3.0 and 2.3.1, but gives no problems with version 2.2.2.
When running the commmand
>gdb paraview
>run
I get the following error...
Starting program: /home/ricardolb/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0/bin/paraview
process 24118 is executing new program: /home/ricardolb/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0/lib/paraview-4.1/paraview
Traceback (most recent call last):
File "/usr/share/gdb/auto-load/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19-gdb.py", line 63, in <module>
from libstdcxx.v6.printers import register_libstdcxx_printers
ImportError: No module named 'libstdcxx'
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffcd2e0700 (LWP 24122)]
[New Thread 0x7fffccadf700 (LWP 24123)]
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff59eccdf in QString:perator=(QString const&) ()
from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
I can finally add that I upgraded my RAM memory about a week ago. I have looked around here and there in the forums and I must say I am pretty lost (considering paraview works in the OF2.2.2. installation, for example...).
Greetings,
Ricardo
RicardoLB is offline   Reply With Quote
Old   October 29, 2015, 10:28
Default Solved...
Ricardo Lopez
I solved it...! I simply deleted the folder "~/.config/ParaView"... (found here: Segmentation fault with paraview 3.10.1)
Now I can forget the morning lost figuring this out...!
Greetings!
Ricardo
wyldckat and Antony_Bosco like this.
Old   November 16, 2015, 09:22
Antony Ashley Raja B
Antony_Bosco is on a distinguished road
Thanks for the post !! I was scratching my head for so long.
Antony_Bosco is offline   Reply With Quote
Thread Tools
Trackbacks are On
Segmentation fault (core dumped) NH1994 OpenFOAM Programming & Development 0 January 9, 2015 02:24
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
Segmentation fault (core dumped) in Axial_Rotor_MRF sam.ho OpenFOAM Running, Solving & CFD 0 March 17, 2014 02:42
Segmentation fault (core dumped) when changing pressure BC jptorol OpenFOAM Running, Solving & CFD 0 September 25, 2013 18:05
Segmentation fault with paraFoam and paraview 3.6.1 on Fedora 11 32 and 64 bit nanes OpenFOAM Paraview & paraFoam 2 September 11, 2009 09:12
