[OpenFOAM] paraview parafoam segmentation fault (core dumped) |
October 29, 2015, 08:46 |
Ricardo Lopez
Rep Power: 12 |
Hey all!
I was working until a couple of hours ago with OpenFOAM and paraview/paraFoam, until I got a "Segmentation fault (core dumped)" error... Out of the blue! I have different versions of OF (2.2.2, 2.3.0 and 2.3.1) installed, and paraview/paraFoam crashes with versions 2.3.0 and 2.3.1, but gives no problems with version 2.2.2. When running the commmand >gdb paraview >run I get the following error... Starting program: /home/ricardolb/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0/bin/paraview process 24118 is executing new program: /home/ricardolb/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0/lib/paraview-4.1/paraview Traceback (most recent call last): File "/usr/share/gdb/auto-load/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19-gdb.py", line 63, in <module> from libstdcxx.v6.printers import register_libstdcxx_printers ImportError: No module named 'libstdcxx' [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". [New Thread 0x7fffcd2e0700 (LWP 24122)] [New Thread 0x7fffccadf700 (LWP 24123)] Program received signal SIGSEGV, Segmentation fault. 0x00007ffff59eccdf in QString:perator=(QString const&) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 I can finally add that I upgraded my RAM memory about a week ago. I have looked around here and there in the forums and I must say I am pretty lost (considering paraview works in the OF2.2.2. installation, for example...). Greetings, Ricardo |
October 29, 2015, 09:28 |
Solved...
Ricardo Lopez
Rep Power: 12 |
I solved it...! I simply deleted the folder "~/.config/ParaView"... (found here: http://www.cfd-online.com/Forums/ope...-3-10-1-a.html)
Now I can forget the morning lost figuring this out...! Greetings! Ricardo |
November 16, 2015, 08:22 |
Antony Premkumar
Rep Power: 10 |
Thanks for the post !! I was scratching my head for so long.
April 28, 2020, 20:07 |
nazim
Rep Power: 7 |
These kind of errors are quite complicated to find out for non specialist of Linux. I have one currently in another post but I just gave up because I have found another way to use paraview one WSL bash
[OpenFOAM] Paraview - Segmentation fault | grjmell | ParaView | 5 | January 9, 2024 13:14 |
[General] Paraview crashes with segmentation fault when using meshes larger than 50M | Ricardo1992 | ParaView | 0 | September 13, 2018 05:20 |
Segmentation fault (core dumped) | Sugajen | OpenFOAM Running, Solving & CFD | 1 | August 2, 2017 12:06 |
Segmentation fault (core dumped) | NH1994 | OpenFOAM Pre-Processing | 0 | January 9, 2015 03:20 |
Paraview fliter problem (surface flow) (segmentation fault) | maysmech | OpenFOAM | 1 | October 6, 2011 11:01 |
