[OpenFOAM] Installation ParaView for Windows version of openFOAM |
January 3, 2016, 04:55 |
kasra karimi
Rep Power: 10 |
Hello everybody
Im really new with the OpenFOAM, and i recently installed the Windows version of OpenFOAM, distributed by its the official website: http://www.openfoam.com/products/openfoam-windows.php but it does not consist ParaView as default. I tried to install paraview for windows but it seems openfoam doesnt still recognize it, in other hand i cant have access to the Linux environment to install it. I would appreciate if anyone could help me how i should install paraview on this version |
January 3, 2016, 10:07 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kasra Karimi and welcome to the forum!
I'll quote from the README file they have on their website: http://www.openfoam.com/products/txt...dme_v3.0.0.txt Code:
-------------------------------------------- Working with OpenFOAM in the Working Folder: -------------------------------------------- 1) Please note paragraphs 2) and 3) of the Installation Procedure. 2) The Working Folder is a shared folder with your username (C:\Users\$UserName) and its content will be available to the container. 3) Copy your case (tutorials, etc.) to the Working Folder C:\User\$UserName, and run OpenFOAM as normal from the command line. 4) Post-processing: i) You will need to install Paraview, as mentioned at the start of this document. ii) On simulation completion, create a file with the suffix ".foam" (e.g "touch a.foam") inside case folder. iii) Launch Paraview, browse the case folder and open the file with suffix ".foam" to start visualizing the case. Bruno
January 3, 2016, 19:50 |
problem solved
#3 | |
kasra karimi
Rep Power: 10 |
(for other who have the same problem): as it says in READMe file, all you have to do is to copy tutorial files into workDir(it will appear in C:\Users\Username) folder and by creating a ".foam" file of the corresponding case, so now you can easily open it through windows version of paraview |
February 4, 2016, 12:50 |
Can't understand
Rep Power: 10 |
Hi everyone!
I'm new at using OpenFoam and can't understand the problem. I followed the readme and your suggestion but the program gives me an error and create nothing in Windows: [ofuser@boot2docker ~]$ ls $ FOAM_RUN OpenFOAM s workingDir [ofuser@boot2docker ~]$ cp -r $FOAM_TUTORIALS $workingDir cp: missing destination file operand after `/opt/OpenFOAM/OpenFOAM-v3.0+/tutorials' Try `cp --help' for more information. Can you help me please? |
February 4, 2016, 17:56 |
#5 | |
kasra karimi
Rep Power: 10 |
I think your problem is the same as mine. you should go to this website http://www.paraview.org/download/ and download the paraView software for Windows and install it. then in your case in openFoam, after making your mesh or finishing the run process, you should make a file which contains your case's informations by this command: Code:
touch cavity(or any name you want).foam that method worked for me and i hope it would be helpful for you. but as a recommendation my friend, its much easier to work with openFoam in linux. "menotu" is a version based on ubunto 12.04 that has some versions of openfoam installed on it by default, which makes it much easier and its really easy to use. Best Regards |
March 8, 2017, 07:43 |
Access openfoam files with local drive in windows
Daniel
Dear Kasra
I'm new with openFoam as well and I followed the steps up to this point. My doubt is how to access/transfer files from the virtual machine to my local drive so I can access it with Paraview. Cheers, Daniel |
March 9, 2017, 03:42 |
Rep Power: 10 |
I suggest you to work in ubuntu, it's way simplier! I tried to work in windows but then I abbandoned it for ubuntu
Omnia per ipsum facta sunt, et sine ipso factum est nihil, quod factum est |
March 9, 2017, 04:46 |
Uwe Pilz
Rep Power: 15 |
The OF version from CFD support works fine. You find it here
http://www.cfdsupport.com/install-op...r-windows.html paraFoam is included, all works at the Windows file system. I use it.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 10, 2017, 04:07 |
#9 |
Daniel
Thanks piu58 I will try that
Thanks for your reply. Last edited by wyldckat; March 25, 2017 at 19:09. Reason: merged posts done a minute apart |
May 11, 2017, 09:33 |
#10 |
Christa
Rep Power: 15 |
I installed Paraview for Windows and it appears to load fine, however I cannot see anything in my viewer, it's literally a back screen. For example, attached in this post is what I see when I load the can.ex2 tutorial. Literally black in the model viewer. I tried adjusting the camera angles, the opacity and the light, viewed surfaces, edges, points, all of these options show the same thing. Same for any other case I tried, including the cavity tutorial. The variables appear to have been loaded fine and the variable ranges are in fact as expected, so it looks like a visualisation problem to me. Anyone else come across it? Have I missed something stupid? Use of Linux is not an option for me so that's out the window. Thanks. |
May 22, 2017, 09:19 |
#11 |
Christa
Rep Power: 15 |
Ok figured it out, I had downloaded a RC1 version of 5.4. I uninstalled that and installed stable 5.3 which works fine. Anyone interested, I guess avoid 5.4 until it becomes stable too.
Cheers, Christa Last edited by user_of_cfx; May 23, 2017 at 06:48. |
January 15, 2018, 16:48 |
Blacks Screen = Known Bug w/Paraview v5.4 or not?
#12 |
Thomas Weeks
Has anyone else verified the buggy v5.4 "black screen" issue?
I'm running the docker container version of OpenFOAM.com's paraview, which IS v5.4, and which gives this useless black-window issue: paraview-5.4_blacksscreen.jpg I don't know if it's a paraview bug.. a docker container issue.. a VM issue.. or what.. I'm going to try installing v5.3 outside the container and see what that gets me. Tweeks |
January 23, 2018, 19:36 |
#13 |
Foad
Rep Power: 8 |
I think one step is missing here. As explained in this nice video you need to convert the project using foamToVTK first and then make the empty dummy .foam file.
June 4, 2018, 10:54 |
#14 |
Nolan Dyck
Rep Power: 12 |
Thanks for the tip foadsf. Using foamToVTK allowed me to visualize meshes at least.
Also user_of_cfx I have found that paraview 5.4+ appears to load .foam cases just fine on Windows 10. I came across the issue only only when using a Windows 7 machine. |
September 8, 2018, 14:06 |
Installation of paraview
#15 |
Tanveer
Rep Power: 7 |
Hai I am new to OpenFOAM and I would like to know the procedure to install paraview. I followed the procedure mentioned in this link: https://www.albertopassalacqua.com/?p=1648
but the error : ''Unable to locate package paraview'' appears . What should I do? |
openfoam, paraview, windows |
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | OpenFOAM | 10 | April 19, 2021 18:06 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Paraview refuses to start after installation of OpenFoam | flotus1 | OpenFOAM Installation | 12 | March 6, 2014 14:42 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
