Home > Forums > OpenFOAM Paraview & paraFoam
Refresh Times does not seem to work (Cavity tutorial)
Old   June 6, 2016, 09:50
Default SOLVED: Results not showing in ParaView (Cavity tutorial)
Bruno
MBttR is on a distinguished road
Just got OpenFOAM (2.4.0 on Ubuntu 15.10 on VirtualBox on Windows 10 64bit) running this morning, now working through the User Guide. I have no previous Linux experience either for that matter.
I'm at the point where I just run paraFoam, verified the mesh and then have to run icoFoam.
I ran paraFoam using
paraFoam &
Then after it opens and I select the formatting for my mesh, I got back to the same terminal window, first have to press Enter (Return) to get a new prompt line, and then use
icoFoam
It runs succesfully (folders are created), and ParaView sees my timesteps from 0 to 0.5 but the screen remains white (except for my black grid). Pressing the 'Refresh Times' button doesn't change anything.
I'm sure it's something trivial, perhaps something in the order I'm doing wrong, but can't seem to find it. I have read following topics to no avail:
icoFoam won't run while Paraview is running
paraFoam does not show results of Cavity tutorial
Thanks a lot,
Bruno
MBttR is offline   Reply With Quote
Old   June 7, 2016, 07:11
Bruno
I have now also stumbled on this post, showing that the tutorial is based on an old ParaView version which complicates the situation: OpenFOAM (2.3.0) guide for ParaView (4.1.0) is not ok with actual software.
Then I've also gone through the first tutorial of The Foam House hoping that would enlighten me, but I have the exact same situation. It does recognize my solution (as it sees the timesteps) and there is data in the newly created directories, but the representation remains blank. I included a picture for clarity. I tried showing different parts of the mesh hoping that would change anything (even though the tutorial says to just show all mesh parts) and jam the Refresh Times button, to no avail.
Hope someone can help, cheers!
Bruno
*edit*
I read something about ParaView not correctly reading .openfoam files, so I ran it like this:
$ touch case.foam
$ paraview --data=case.foam
As mentioned here: ParaView doesn't work:
Doesn't work. Exact same situation as above.
Old   June 7, 2016, 08:53
Bruno
Right!
Time to call me stupid, I deserve it. For those that somehow have the same oversight (and they exist! I've seen the topics!), the solution is shamefully simple. I read over the "Select *parameter* in coloring" sentence, where you have to select either p or U. Seems a bit weird that they're first spending a whole paragraph on formatting your color and then fly over that part without showing a screenshot, but okay, my fault for reading too fast. Good thing is it's solved and I can continue. I'll give myself both a slap in the face and pat on the back.
Ciao!
Thread Tools
Trackbacks are On
Problem in Cavity tutorial itsme_kit OpenFOAM 2 December 29, 2013 14:33
refineMesh -parallel crashes (in cavity tutorial) andras OpenFOAM Mesh Utilities 0 August 8, 2010 14:52
motorBike tutorial doesn't work out-of-the-box Wolle OpenFOAM 23 April 21, 2010 08:19
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Canbt run the tutorial cavity fengxs OpenFOAM Installation 4 May 10, 2005 13:18
