[OpenFOAM] Can not run paraview from OpenFoam |
August 20, 2016, 23:22 |
Ontario
I installed Paraview, but when I try to view the mesh Open Foam can't open Paraview and it shows me the following msg: "worrning/ can not build paraview plugin (s) without paraview directory" Thanks for nay help! Adam |
August 25, 2016, 22:34 |
have you installed Paraview from third-parties of OpenFoam.
Try to install a Paraview 4.3 from http://www.paraview.org/download/ in the run-case directory, creat a Case.foam empty file and open it in Paraview |
August 29, 2016, 11:17 |
#3 | |
Ontario
Thank you for your reply. Although I installaed ParaView 4.3 in the Third-parties directory of the OpenFOAM, still didn't work. I got the following message: Cannot build Paraview plugin without paraview directory Paraview_DIR = /opt/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/Paraview-5.0.1 I appreciate your help Adam |
mesh, paraview, pre-processing |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM can't be run in parallel in cluster | sibo | OpenFOAM Running, Solving & CFD | 4 | February 21, 2017 16:29 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
