Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Plotting average Temperatures over line
Like Tree3Likes
  • 3 Post By gschaider
Old   October 28, 2016, 12:40
Default Plotting average Temperatures over line
astronauti is on a distinguished road
i have a cooler where the exhaust and the water flow is in the same directory (z directory). Now I want to plot the average Temperature in the xy-plane over the z Axis, to see how the Average-Temperature changes over the z-axis. Is this possible with paraFoam.
astronauti is offline   Reply With Quote
Old   October 30, 2016, 12:26
Assistant Moderator
Bernhard Gschaider
The way I would do it (but I'm extremely biased) is with a swak4Foam-function object (this would be in controlDict):
libs (
    "libsimpleSwakFunctionObjects.so"
functions {
    temperatureLine {
        type swakExpressionAverageDistribution;
        outputControlMode outputTime;
        valueType internalField;
        expression "T";
        weight "vol()";
        mask "true";
        abscissa "pos().z";
        binNumber 100;
        valueIfZero -666;
This would generate files with the data every time the regular field data gets written (averages are calculated volume-weighted)
Disadvantage is that you will have to install swak4Foam
Bana, Luttappy and astronauti like this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 30, 2016, 15:40
Thank you very much. Swak4foam was already installed, so thats no problem. Managed to get it working for a multiRegion simulation. Whats the difference between the value in key and raw?
Old   October 30, 2016, 16:28
Assistant Moderator
Bernhard Gschaider
You have already been tempted by the Dark Side? Good for you.
"Key" should be the value of the abscissa (in your case z). "Raw" is the weighted average (long story. The name was inherited and I never bothered to change it). "Min" and "Max" should be obvious. "nSamples" is the number of cells that fell into the bin defined by "key" (the sad truth is that it doesn't really "cut" through the simulation but just looks at the cells. But that is much faster and "good enough")
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 06:44
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
