Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraview greek symbols
Like Tree4Likes
  • 1 Post By wyldckat
  • 2 Post By wyldckat
  • 1 Post By heliana60
Old   February 24, 2009, 08:00
Default paraview greek symbols
Preibie
Hallo,
I use since some months paraview. I want to use greek symbols in the toggle color legend. Should I use a special syntax ore must I install a package?
thanks for helping
Old   November 4, 2010, 05:30
Default math and greek fonts in paraview
Daniel
nihil is on a distinguished road
hi there!
I want to use math and greek characters in my paraview files too.
does anyone know how to do that?
thanks
daniel.
nihil is offline   Reply With Quote
Old   January 11, 2012, 09:48
tonkiplis is on a distinguished road
I am trying to do the same, were you able to solve this issue?
Cheers,
Thierry
tonkiplis is offline   Reply With Quote
Old   January 15, 2012, 09:31
Retired Super Moderator
Bruno Santos
Greetings to all!
I suppose you guys haven't been using an online search engine
Here's what I found out:
edit: Nonetheless, this seemed to have been introduced into VTK back in 2009: http://www.vtk.org/cgi-bin/gitweb.cg...ec5e174058bf34 - but it doesn't seem to have been brought to ParaView.
Best regards,
Bruno
Tobi likes this.
Old   February 13, 2013, 05:58
Bruno Santos
This is a very old thread, but in order to keep things in the same place, here's an update on this situation: http://markmail.org/message/oj46ltqgr5s3zen2
ParaView 3.98.1 is now available for download ((http://paraview.org/paraview/resources/software.php). [...]
Some of the major fixes are:
- Math-text in annotation: ParaView 3.98.0 introduced support to add annotations with math-text. This release extends on that capability to support math-text in several annotations including Text source, chart titles, scalar bars. Simply use $<math-text>$as the text to use. Anything within the $...$ symbols will be treated as math-text and rendered using matplotlib.
I haven't tested this yet, so I don't know to what extent this will work.
Best regards,
Bruno
Tobi and chengyu like this.
Old   December 24, 2014, 07:32
Ivan
lt.quibbler is on a distinguished road
Thanks for the hint, Bruno!
Worked perfectly for me. Paraview version 4.1.0.
Regards,
Ivan
lt.quibbler is offline   Reply With Quote
Old   June 17, 2015, 05:25
Default latex paraview
Heliana Cardenas
heliana60 is on a distinguished road
Hi there,
hi did you make this work? it does not work for me,
heliana
heliana60 is offline   Reply With Quote
Old   June 17, 2015, 14:42
Bruno Santos
Quick questions:
  1. Which ParaView version are you using?
  2. How was that ParaView version installed?
  3. What steps did you do for using this feature?
Old   June 18, 2015, 04:47
Heliana Cardenas
Hi Bruno,
1. Paraview version 4.1.0 64bits
2.
I downloaded Paraview from wget http://downloads.sourceforge.net/pro...arty-2.3.0.tgz
then I compiled OpenFoam and the Paraview with ./makeParaView4 and then I do:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
wmSET
./Allwclean
./Allwmake
3. For using this feature I put the symbols between dollar signs when I want to include a text or a legend, is it supposed to be like this?
Thank you for replying !
Heli
Old   August 18, 2015, 16:20
Bruno Santos
Hi Heliana,
Sorry for the late reply, but only today did I finally manage to look into this.
The detail is that since this feature requires "matplotlib", this means that you need to build ParaView with the Python integration.
Therefore, either:
Best regards,
Bruno
Old   August 19, 2015, 07:47
Heliana Cardenas
Hi Bruno!
I managed in the end I had to set the python library manually in the paraview compiler, and now it works fine
thank you for answering !
Heliana
wyldckat likes this.
Old   January 5, 2021, 15:37
Cpt. Convergence
Captain Convergence is on a distinguished road
Hi all!
I came accross this post and I am wondering if anyone has found the solution to this issue with the greek letters. As you can observe in the screenshot that I have attached, the latex math language is not being respected at all
Thank you in advance!
Captain Convergence is offline   Reply With Quote
Old   January 5, 2021, 15:58
Cpt. Convergence
Wops I came up with the solution by accident. I leave here the solution if someone is interested in using python scripting
[OpenFOAM] ParaView Properties Symbols bowen1024 ParaView 1 April 18, 2017 14:39
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[General] ParaView 5 Greek symbols kmou ParaView 0 March 1, 2016 11:03
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
