Error in Paraview
Hi All
i got error message when tried to simulate a case from channelOodles tutorial on the ParaView3.3-cvs please see error message below error message in the terminal : user@user-laptop:~/OpenFOAM/user-1.5/run/tutorials_user1/channelOodles/channel395$ paraFoam ERROR: In /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkDataSet.cxx, line 406 vtkPolyData (0xb255210): Point array k with 1 components, only has 2028 tuples but there are 2132 points ERROR: In /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkExecutive.cxx, line 757 vtkCompositeDataPipeline (0xbb20c60): Algorithm vtkPVGeometryFilter(0xbb1ddc0) returned failure for request: vtkInformation (0xbbd8690) Debug: Off Modified Time: 128922 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 error message that showed up on the Paraview 3.3 display (pop up) : ERROR: In /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkDataSet.cxx, line 406 vtkPolyData (0xb255210): Point array k with 1 components, only has 2028 tuples but there are 2132 points ERROR: In /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkExecutive.cxx, line 757 vtkCompositeDataPipeline (0xbb20c60): Algorithm vtkPVGeometryFilter(0xbb1ddc0) returned failure for request: vtkInformation (0xbbd8690) Debug: Off Modified Time: 128922 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 anybody has experience with this case before? any suggestion how to fix it? many thanks |
