Home > Forums > OpenFOAM Paraview & paraFoam
Problem with paraview and paraFoam
Like Tree1Likes
Old   February 26, 2009, 06:33
Default Dear OF users, My problem i
  #21
stephane sanchi
openfoam_user is on a distinguished road
Dear OF users,
My problem is always unsolved !!!!!!!!!
ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398
vtkXOpenGLRenderWindow (0x13476b0): Could not find a decent visual
X Error: BadValue (integer parameter out of range for operation) 2
Extension: 144 (Uknown extension)
Minor opcode: 3 (Unknown request)
Resource id: 0x21
ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 623
vtkXOpenGLRenderWindow (0x13476b0): Cannot create GLX context. Aborting.
Nobody has had the same error message in the past ?
Thanks for helping me.
Regards,
Stephane
openfoam_user is offline   Reply With Quote
Old   March 6, 2009, 06:15
Default Hi, try to download the bin
  #22
Achim Frahm
achimfrahmmunterscom is on a distinguished road
try to download the binaries for your system directly from kitware. So you are sure that your problems have nothing to do with wrong compilation and/or version. When i did it, i was sure that my grafic card was the reason!
http://www.paraview.org/paraview/res.../software.html
Achim
achimfrahmmunterscom is offline   Reply With Quote
Old   March 17, 2009, 04:53
Default I have same problem
  #23
Sergei D.
Se9a is on a distinguished road
I have same problem
sega@sega:~/OpenFOAM/sega-1.5/run/tutorials/icoFoam/cavity> paraFoam
ERROR: In /home/sega/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 398
vtkXOpenGLRenderWindow (0x132c320): Could not find a decent visual
Resource id: 0x21
ERROR: In /home/sega/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 623
vtkXOpenGLRenderWindow (0x132c320): Cannot create GLX context. Aborting.
I use openSUSE 11.1, grafic card nVidia 6800 ultra or nVidia NVS 140M, nVidia drivers.
Se9a is offline   Reply With Quote
Old   March 17, 2009, 05:09
stephane sanchi
Hi Sergei,
you have the same problem as mine which is unfortunately still unsolved !
I also use openSUSE 11.1, graphic card nVidia and nVidia driver.
Keep me updated if you find how to solve this problem.
Regards,
Stephane.
Old   June 28, 2009, 07:31
alex
oort is on a distinguished road
Hi!
I have the same problem.
Curiously paravfoam/paraview works after an fresh opensuse installation without updating the nvidia driver.
So the only thing I can tell you is: remove the nvidia driver.
If you do that you loose the driver features (3d aceleratuion, etc) but you can work...
It is a poor solution but it is the only way i can work
My system is a laptop with:
OpenSuse 11.1
OpenFoam 1.5
Qt 4.3.5
NVidia GeForce 9200M GS
My question here is: this only happens with openSuse or also with other linuxes?
Because if it only happens with OpenSuse i will try to change to ubuntu. If happens with any OS it its a problem of graphic board software.
oort is offline   Reply With Quote
Old   June 28, 2009, 13:17
Default I have a solution
  #26
Sergei D.
Hello!
I have a solution to the problem. I have installed the ParaView 3.4 from source and Native OpenFOAM Reader for ParaView from here. This works very well on OpenSUSE 11.1 with OpenFOAM 1.5, NVidia Quadro NVS 140M, QT 4.4.3 and NVidia drivers.
Old   August 26, 2009, 03:14
stephane sanchi
I have installed OpenFOAM-1.6 under Linux 11.1.
My problem with paraFoam has disappeared.
Now paraFoam (paraview 3.6.1) runs well.
Regards,
Stephane.
Old   January 7, 2010, 16:55
Default Alternative solution
  #28
Thomas Clark
t_clark is on a distinguished road
This is a problem with the glx module, not with paraview.
Try running glxgears and glxinfo. That will test whether the glx module is working correctly.
One suggestion is to try running them as root - in my case, a permissions error was preventing various libraries from loading. Everything worked fine as root, though.
Incidentally, I experienced the problem using OpenSUSE 11.1, an NVIDIA QuadroFX1700 in a Dell T7400 workstation, with current drivers from the NVIDIA repository.
As it was a permissions error, I did not need to edit xorg.conf at all.
** Edit ** I had already gone through installing paraview from source, with the appropriate version of Qt - it might be worth checking this permissions issue first.
t_clark is offline   Reply With Quote
Old   May 25, 2010, 16:42
Default GLX and paraview
  #29
chegdan's Avatar
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
I had been receiving the error:
when starting parafoam and resolved it by deleting all nvidia drivers and packages and reinstalling them. After that, the glxgears and glxinfo worked like a charm...as well as parafoam. this is all in Ubuntu 9.04 amd64 with OF-1.5-dev of course with paraview 3.3. This was an issue with glx module.
chegdan is offline   Reply With Quote
Old   June 11, 2011, 11:07
Suresh kumar Kannan
kumar is on a distinguished road
Hello ,
one of the solution that worked for me was this:
http://www.starnet.com/xwin32kb/Coul...uffered_Visual
if your ./ALLclean
./makeparaview
and
  • ./Allwclean
  • ./Allwmake
did not give any error message and you get the error
ERROR: In /home/local/UNI/kumar.kannan/OpenFOAM/ThirdParty-1.7.x/paraview-3.8.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 404
vtkXOpenGLRenderWindow (0x26398b0): Could not find a decent visual
Extension: 128 (Uknown extension)
Resource id: 0x21
ERROR: In /home/local/UNI/kumar.kannan/OpenFOAM/ThirdParty-1.7.x/paraview-3.8.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 631
vtkXOpenGLRenderWindow (0x26398b0): Cannot create GLX context. Aborting.
then try to just run
export LIBGL_ALWAYS_INDIRECT=1
then try opening paraFoam or paraview.
it should work.
regards
K.Suresh kumar
Daniel Sinka likes this.
kumar is offline   Reply With Quote
Old   July 19, 2011, 06:02
Ira Sheinman
Ira_Sheinman is on a distinguished road
Hi! I'm begginer in openFoam and Linux. Now I'm using CAE-Linux 2008 Live DVD. I don't install OS and openFoam on my hard disk. When I lunch paraview, I see the message
XLib: extension "GLX'' missing on display': 0.0". line 75 : 27415 Aborted. paraview paraFoam.pvs.
What is wrong? Many thanks for any advice.
Ira_Sheinman is offline   Reply With Quote
Old   July 19, 2011, 06:24
Suresh kumar Kannan
HI
The message is clear glx libraries are not installed
Type glxinfo on command prompt
If the packages are not installed install openGL and glx
then try it
check this site it may help.
regards
K.SUresh kumar
Old   July 20, 2011, 04:16
Ira Sheinman
Many thanks, kumar!
Old   November 22, 2011, 16:39
jdiorio is on a distinguished road
Originally Posted by kumar View Post
Hello ,
if your ./ALLclean
./makeparaview
and
  • ./Allwclean
  • ./Allwmake
Resource id: 0x21
it should work.
regards
K.Suresh kumar
Thanks Kumar - that worked for me.
jdiorio is offline   Reply With Quote
Old   January 9, 2013, 20:40
cnd
Chris
cnd is on a distinguished road
This is all that you need to fix it:-
cnd is offline   Reply With Quote
Old   June 10, 2013, 00:04
Default Found solution
  #36
Ildebrando
Ildebrando is on a distinguished road
Hi Stephane,
I had exactly the same problem. I know you already solved by changing the paraview version it but I hope this could be useful
http://ubuntuforums.org/archive/inde...t-1418849.html
Originally Posted by openfoam_user View Post
Dear OF users,
When i want to lauch paraview (or paraFoam) I got the following error message :
vtkXOpenGLRenderWindow (0x1289b90): Could not find a decent visual
Extension: 129 (Uknown extension)
Resource id: 0x21
vtkXOpenGLRenderWindow (0x1289b90): Cannot create GLX context. Aborting.
Could someone help me to solve this problem. Thanks in advance.
Stephane.
Ildebrando is offline   Reply With Quote
Old   May 13, 2014, 07:37
cfd_engineer_2014 is on a distinguished road
Hello ,
if your ./ALLclean
./makeparaview
and
  • ./Allwclean
  • ./Allwmake
Resource id: 0x21
it should work.
regards
K.Suresh kumar
Thanks Kumar! This worked for me, too.
cfd_engineer_2014 is offline   Reply With Quote
Thread Tools
Trackbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.cfd-online.com/Forums/openfoam-paraview/61051-problem-paraview-parafoam.html
Posted By For Type Date
Untitled document This thread Refback July 13, 2009 13:10
Error starting paraFoam line 67 paraview command not found jango OpenFOAM Installation 4 July 19, 2007 01:39
Both paraview and paraFoam crash on Redhat Linux WS v4 64bit sek OpenFOAM Paraview & paraFoam 4 August 17, 2006 16:26
ParaFoam conflicting version of paraview xponticq OpenFOAM Paraview & paraFoam 3 May 16, 2006 12:52
Building Paraview with reader builtin instead of parafoam script tj22 OpenFOAM Paraview & paraFoam 2 April 7, 2006 12:55
Problem running paraFoam paraview command not found spdracer22 OpenFOAM Pre-Processing 2 December 7, 2005 06:32
