Home > Forums > OpenFOAM Paraview & paraFoam
ParaView small graphical window
Old   December 29, 2008, 01:01
Default Hi all! Sorry, I am newbie
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi all!
Sorry, I am newbie to this Forum, first time I have posted this message in wrong thread.
I have installed OpenFOAM following README instructions for my Kubuntu 8.04.1. After that cavity tutorial did not work at stage of runnig 'paraFoam' asking for proper reader plugin. So I found solution at this forum to recompile ParaView and PV3FoamReader (as it is pointed in README). Now it starts, but after loading cavity geometry representation window is to small (output region is about only 1/8 of total graphics window, other part is black). I attached the printscreen for better understanding:
Mesh drawing is to small that I could not see almost anything. Perhaps it is connected somehow with OpenGl settings? I have NVIDIA Quadro FX 1400 with drivers installed from nvidia home site. Waiting for your suggestions! Thank you!
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Advanced Process Simulation of
Solidification and Melting"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
Franz-Josef-Str. 18
A - 8700 Leoben
Österreich / Austria
Tel.: +43 3842 - 402 - 3125
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   January 6, 2009, 05:50
Default Full rebuilding of ParaView3 a
Full rebuilding of ParaView3 according to http://paraview.org/Wiki/ParaView:Build_And_Install solved the problem!
Best regards,
Franz-Josef-Str. 18
A - 8700 Leoben
Old   January 8, 2009, 14:28
Default Hi, Dr. Vakhrushev, After i
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, Dr. Vakhrushev,
After installing OpenSUSE 11.1 64 bit OS, I started to have the same problem as yours. the same computer had OpenSUSE 10.2/10.3/11.0 and never had this problem.
did you also rebuild cmake? which version?
Or did you follow the exact steps given in the Paraview3 wiki? How did you handle the paraview reader compilation so that it can be invoked by paraFoam?
Thanks!
Pei
hsieh is offline   Reply With Quote
Old   March 5, 2009, 10:16
Default Paraview showed the same windo
Achim Frahm
achimfrahmmunterscom is on a distinguished road
Paraview showed the same window on my computer.
(Also Quadro FX 1400)
Full rebuilding of ParaView3 according to http://paraview.org/Wiki/ParaView:Build_And_Install did not solved the problem!! (Also rebuild of cmake)
The reason was the grafic card!! After a change to FX 3700 window was correct. Very funny. Maybe the API or the card had an error - but it worked 2 years with a kommercial code quite properly.
Achim
achimfrahmmunterscom is offline   Reply With Quote
Old   March 5, 2009, 10:25
Default We've started encountering sim
Mark Olesen
olesen will become famous soon enough
We've started encountering similar issues with some of the newer nvidia drivers (Linux). It even appears that some are swallowing a few keyboard/mouse events, but we're not really sure what is causing it all.
olesen is offline   Reply With Quote
Old   March 23, 2009, 05:48
The solution was to install in Kubuntu cmake through apt, change all cmake flags to system's and to recompile. I've made instruction during this troubleshooting) So enjoy from http://docs.google.com/Doc?id=dg65zmzw_427gmwtdscg
Best regards,
Franz-Josef-Str. 18
A - 8700 Leoben
Thread Tools
Trackbacks are On
Graphical viewer for blockMeshDict grtabor OpenFOAM Pre-Processing 22 March 14, 2013 04:05
ParaFoam small graphical window makaveli_lcf OpenFOAM Bugs 0 December 26, 2008 06:42
Graphical error hesam FLUENT 0 February 10, 2007 05:15
Graphical technics indd Main CFD Forum 2 October 21, 2004 08:19
Graphical pressure distribution from a cut Aline CD-adapco 3 August 4, 2004 11:50
