-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   ParaFOAM 3Dwindow doesnbt show results continuously (http://www.cfd-online.com/Forums/openfoam-paraview/61060-parafoam-3dwindow-doesnbt-show-results-continuously.html)
dresi January 29, 2009 10:30
Hi everybody, I have a prob
Hi everybody,
I have a problem with the 3D window of paraFoam:
When I want to display something like a mesh or a flow field, anything, it just shows the picture when I click on it, or when I rotate the mesh.
I can work with paraFoam, it is just annoying.
Is this a setting I can change or is there an other solution for this problem?
(Ubuntu 8.10, OF 1.5)
Thankful for hints, ttips and tricks,
Andreas
yile_li February 20, 2009 00:19
Andreas, I had the same pro
Andreas,
I had the same problem for my Ubuntu 8.10/OF 1.5. I tried different versions of paraview - 3.2, 3.4, 2.6 and they all had the same problem - the objects are visible only when mouse button are clicked and otherwise the display window is white. After one day struggle, I thought maybe there are some conflicts between Paraview and Ubuntu display configuration. I went to System/Preferences/Appearence/Visual Effects and changed the visual effects level from Normal to None. It worked. The display window in Paraview becomes black and I can see objects and change view angles without keeping the mouse button clicked. Hope this helps.
Cheers,
Yile
