Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to tell paraFoam what data to use
Old   February 13, 2009, 17:05
Default How to tell paraFoam what data to use
BastiL
bastil is on a distinguished road
I have a minor problem I could not solve so far. Running paraFiew from a OF case for me always reads the data from the 0/ directory. However I want to read the last time. There is no option like -lastTime, so how can this be done.
Regards BastiL
bastil is offline   Reply With Quote
Old   February 13, 2009, 19:19
Default Hi Bastil OF will rea
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Hi Bastil
OF will read all the data at different time. If you want to see data at the final time, just change into the last time point using the animation button.
If you don't want load other time point data, delete it or move to other directory.
Junwei
su_junwei is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[General] Advice on post processing compressor blade data in paraview Jack001 ParaView 0 February 4, 2016 17:16
redistributeMeshPar with scotch fails matteoL OpenFOAM Pre-Processing 0 March 30, 2015 11:13
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 15:15
[OpenFOAM] Multiple independant data sets in paraFoam christian ParaView 1 August 27, 2007 12:30
