OF15 for Ubuntu804 buildParaView33cvs stoped suddenly
i compile the paraview as what the Readme said, but the compilation stopped suddenly at 37%. the putout in terminal as follow:
..... [ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkViewportCli entServer.o [ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkVoxelClient Server.o [ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkWedgeClient Server.o [ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkFilteringCS Init.o Linking CXX shared library ../../../bin/libvtkFilteringCS.so [ 37%] Built target vtkFilteringCS make: [all] error 2 i was a new learner, hope someone can tell me what's the problem? thanks in advance |
I have the same prob
I have the same problem. Anyone here who solved it or has an idea? Thanks in advance and Greetings, Axel |
try running the build utility
try running the build utility with the -d option to get more details on the error
-Louis |
Possible solution ParaView and PV3FoamReader?
Hello All,
I was having the exact same issue as mentioned at the top of the thread. I am running Ubuntu 9.04 QMake 4.3.5 CMake 2.4-patch 6 gcc 4.3.1 I did some digging by going into the actual ThirdParty/ParaView3.3-cvs/platforms/linuxGcc directory and directly running the make -d command as mentioned by another poster. This revealed the system was missing some sort of X11 strings header file "StringDefs.h" The point is, by issuing apt-get install xorg-dev, ALL of the problems compiling ParaView and PV3FoamReader were immediately solved. I am not sure if this issue is explicitly documented somewhere, that this is a required dependancy of ParaView or OpenFoam? If so, I was not able to locate it. Should this be added to some documentation for compiling ParaView? Chris |
I am not quite sure if this would help. But there is a thread on the compilation of paraview on this link :
http://www.cfd-online.com/Forums/ope...-script-4.html Maybe you can take a look and see if it helps. Thanks. |
