Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] SnapShot appears as Black image
Old   January 29, 2009, 07:28
Default SnapShot appears as Black image
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
Hello Foamers,
I could not able to make either screen shot nor movies due to the subject problem. In the paraFoam monitor both the picture and movies shows fine. But when i start to write them then everything looks like Black images....
if anyone faced this problem, pls let me know. It takes lot of time ...
Thanks
maruthamuthu_venkatraman is offline   Reply With Quote
Old   January 29, 2009, 14:14
Default Hi Maruthamuthu This probab
Michael Wild
mwild is on a distinguished road
Hi Maruthamuthu
This probably is a problem with off-screen rendering. Go to the Options/Preferences dialog and on the page called "Render View" switch off the "Use Offscreen Rendering for Screenshots" setting.
Hope this helps
Michael
mwild is offline   Reply With Quote
Old   January 30, 2009, 03:22
Default Thanks a ton! Micheal... I
It solved the problem...
[ANSYS Meshing] How to generate mesh from segmented image paoching ANSYS Meshing & Geometry 0 March 21, 2019 13:37
Black screen appears when trying to Open Fluent M.Shousha FLUENT 1 November 10, 2018 09:57
[Other] Support for the USB-stick image and Virtual Machine Appliance for the OFW11 wyldckat OpenFOAM Installation 2 August 7, 2016 17:50
Infrared Image kind of Temperature snapshot ankur_kr FLUENT 0 July 11, 2013 23:03
Extracting Information from Instantaneous Snapshot sgg303 Main CFD Forum 0 October 31, 2012 04:51
