Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview 34
Old   November 22, 2008, 11:47
Default Paraview 34
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, OpenFOAMers:
Current OpenFOAM works with paraview 3.3, correct? Has anyone tried compiling paraview 3.4? I am not talking about using foamToVTK. I am interested in using paraFoam. Thanks!
Pei
hsieh is offline   Reply With Quote
Old   November 22, 2008, 12:08
Default Hi Pei! Have a look at my p
Assistant Moderator
Bernhard Gschaider
Hi Pei!
Have a look at my posting this week:
http://www.cfd-online.com/OpenFOAM_D...7262#POST28900
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 22, 2008, 15:22
Default Hi, Bernhard, Thanks a lot
Pei-Ying Hsieh
Hi, Bernhard,
Thanks a lot for the reply. I will give it a try tonight.
Pei
PS: I did do some search on the forum before I posted. I should have done a more thorough search first.
Old   January 26, 2009, 13:06
Default Hi Bernhard. Could you pl.
Sayantan Datta Gupta
rishi123 is on a distinguished road
Hi Bernhard.
Could you pl. help me out with installin paraview 3.4 in mandriva 2009.
At present OpenFoam1.5 uses paraview 3.3 which is havin a problem with the qt version. the pv3.3 requires qt 4.3 but i suppose that pv3.4 doesn't have any such sort of restraints.
Buddy counting on you.
Rishi
Rishi
rishi123 is offline   Reply With Quote
Old   January 26, 2009, 14:31
Default Hi Rishi! I don't know noth
Assistant Moderator
Bernhard Gschaider
Hi Rishi!
I don't know nothing about Mandriva. Am not sure about the requirements for pv3.4 but I'm afraid it'll need at least the same qt-version (if not higher) as pv3.3
Sorry
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) dslbkxd OpenFOAM Installation 1 February 3, 2018 00:56
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
