Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Problem with xy plot
Old   April 8, 2008, 05:55
Default Problem with xy plot
Vivien
sunnysun is on a distinguished road
Hi, everyone
I have a problem with x-y plot in paraview. I tired with several tutorials but seems i could not get the velocity profile accross a single line.
For example after i run with icofoam and start the paraview,the steps are:
1)select a time instance
2)filter-> append dataset
3)filter->probe
Then I select 'line' as a probe object and specify two points.
However, only pressure(or maybe only scalar) can be plotted, Ux, Uy, Uz are not appeared in the'point scalars'.
Any one has some idears? Thanks in advance!
sunnysun is offline   Reply With Quote
Old   April 8, 2008, 07:48
Default Hi Qii, Maybe, you can have
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi Qii,
Maybe, you can have a look in the user guide chapter 7.5: Sampling data for plotting graphs. It is about the sample utility.
I think It will be usefull :o)
regards,
Cedric
cedric_duprat is offline   Reply With Quote
Old   April 9, 2008, 03:14
Default Hi, Cedric, Thanks for your
Vivien
Hi, Cedric,
Thanks for your idea. But does it mean that I did not follow the right steps?
Qi
Old   January 13, 2009, 09:51
Default Hi, I have the same problem, c
Ali Mansouri
alimansouri is on a distinguished road
Hi, I have the same problem, can anybody help ?
only pressure can be plotted in Paraview 2.4, Ux, Uy, Uz are not appeared.
alimansouri is offline   Reply With Quote
Old   April 23, 2009, 06:42
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Did you first use 'Ucomponents' to break the velocity into its repective components or use 'magU' to get the magnitude of the velocity? Then Ux, Uy and Uz or magU should appear as they are scalars.
Hopefully this helps,
Philip C
bigphil is offline   Reply With Quote
Old   April 23, 2009, 06:52
bigphil's Avatar
Philip Cardiff
I am using OpenFOAM v1.4.1
Possibly the commands in OpenFOAM v1.5 are:
"foamCalc components U"
or
"foamCalc mag U"
Problem diverges when exhaust valve opens swerner0711 AVL FIRE 0 September 21, 2018 07:14
A problem on the Energy spectrum plot by using FFT Martin duan OpenFOAM Post-Processing 5 February 22, 2016 10:12
Problem with Residual plot raising up to hige numbers na do not converge fardinkhalili STAR-CCM+ 4 March 25, 2014 09:35
X-Y plot problem, please help tobytoby FLUENT 8 March 20, 2013 20:57
CFD post vector plot problem bharath CFX 3 February 8, 2011 17:16
