Cp plot on foil along section
How can I do that? Typical aerofoil section in 3D; i d like to extract pressure along a section and plot it. Anything better than having to export to ensight? Thanks, Nicolas |
I also need to plot pressure a
I also need to plot pressure along an airfoil surface. What I tried are:
- Use "cut" utility under "Filter" submenu to extract he intersection of the foil and z = 0 plane - Use "Append datasets" (I'm not sure whether I need this step) - Then , use "Probe" to plot the surface quantities I want. When I did all this, the x-y plot shows zero pressure. What did I do wrong? What does the x-aixs rerepsent? I want to make it x-coordinate of the point on the curve. |
plot over a line is very simpl
plot over a line is very simple in paraFoam.
ploting pressure along airfoil surface is best done with the "sample"-Tool. go look at http://www.cfd-online.com/OpenFOAM_D...s/1/10206.html |
