November 27, 2008, 05:45 |
Plot over line different cases
Pattyn Eric
Rep Power: 17 |
i would like to "plot over a line" the temperature of different cases (same geometry but different meshes, different turbulence models) in the same graphic in order to compare easely the different simulations. I only can plot variables of one case. It means that if i have two cases, i have automatically two graphics. Is it possible to do that with paraview? An other possibility would be to export the values of each separated graphs and to use an other tool to make one graphs with the different curves. Is it possible to write a text file or export the values of my plot over line? |
November 27, 2008, 11:47 |
use utility sample
Matvey Kraposhin
Rep Power: 21 |
use utility sample
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
[Gmsh] Structured meshing in Gmsh | the_phew | OpenFOAM Meshing & Mesh Conversion | 19 | August 24, 2022 03:19 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 29, 2015 23:42 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
