Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to plot change in pressure over time for a point in the mesh
Old   October 14, 2008, 03:32
Default How to plot change in pressure over time for a point in the mesh
Johan Svensson
johan is on a distinguished road
Hi!
I'm using the engineFoam tutorial and want to plot the change in pressure for a point in the cylinder for different times (crank angles). Now I have plotted pressure over a line in the cylinder, and I get a plot of the pressure over this line for every time step (crank angle), and if I shorten the line it is approximately a point. Of course I can browse through all these plots to see how the pressure increases/decreases.
But how do I do to plot the pressure of a point directly against the time?
I appreciate any hints.
Thanks,
Johan
johan is offline   Reply With Quote
Old   October 14, 2008, 08:21
Default Johan, I assume you are cur
Robert Manning
bobatpurdue is on a distinguished road
Johan,
I assume you are currently using Paraview to create these plot. You may concider using the sampling utility in OpenFOAM. This will extract the pressure (or other parameters) at each time step. Then use your favorite plotting package. See http://www.opencfd.co.uk/openfoam/doc/sample.html
for details.
Bob
bobatpurdue is offline   Reply With Quote
Old   October 15, 2008, 03:08
Default Thanks a lot Bob, this seems t
Johan Svensson
Thanks a lot Bob, this seems to be very useful!
Johan
Old   November 11, 2008, 19:56
Default Bob, I am so sorry I don't
Venus Hon Sau Fong
fong909 is on a distinguished road
Bob,
I am so sorry I don't know how to get the data. In the tutorial "solidDisplacementFoam", how can I get the data (pressure versus time or U versus time)? Where did these data store?
Venus
fong909 is offline   Reply With Quote
Old   November 12, 2008, 07:21
Default This may sound like (and proba
Leonardo Honfi Camilo
lhcamilo is on a distinguished road
This may sound like (and probably is) a very dumb question(so bear with me), I had a naca0012 profile wing which I solved with simpleFoam, I wa wondering if it was possible to extract the pressure distribution (data) along the surface (cross-section) of the wing.
I though that sampleSurfDict would do that trick but I still was not able to find the data distribution over the surface
any tips?
thanks in advance
leo
lhcamilo is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 06:51
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
