Home > Forums > OpenFOAM Paraview & paraFoam
Mass flow rate with Paraview 330
Old   October 13, 2008, 12:17
Default Hi, I would like to know h
Marta Colomer
marta_colomer is on a distinguished road
I would like to know how to calculate mass flow rate through boundary patches with Paraview 3.3.0. I used to work with Paraview 2.4 and I obtained mass flow rate by using two different methods:
1. Filter "Extract Parts" + filter "Calculator" + filter "Surface Flow"
2. Using "Ucomponents" + filter "Extract Parts" + filter "Calculator" + filter "Integrate attributes"
The problem comes when I try to apply these procedures with the new Paraview. "Surface flow" doesn't seem to be active in the filter menu and any time I try to use "Ucomponents" with OpenFOAM 1.5 it says "command not found". Can anybody help me?
Thank you very much
Marta
marta_colomer is offline   Reply With Quote
Old   October 13, 2008, 20:27
Default Hi Marta, Have a look at my
Takuya OSHIMA
7islands is on a distinguished road
Hi Marta,
Have a look at my post on May 16, 2008 [1]. It should work regardless of which reader you are using (vtkPOpenFOAMReader or PV3FoamReader).
If you make frequent use of the filter, another way might be to try the latest CVS head of ParaView or wait a bit for the upcoming 3.4 release. Surface Flow in those versions should run straight from the reader output.
[1] Native ParaView Reader Bugs post #61
Takuya
Last edited by wyldckat; November 23, 2014 at 16:19. Reason: replaced broken link with the correct current link, thanks to Takuya's mention of the date of the post!
7islands is offline   Reply With Quote
Old   October 14, 2008, 10:27
Default Hi Takuya, Thanks for your
Marta Colomer
Hi Takuya,
Thanks for your reply. I read your post, but eventhough I could run "Surface Flow" properly, the results, as you said, aren't that accurate. Regarding "calcMassFlow", as far as I know it's thought to be used with incompressible flow and since I'm working with cavitation I'm afraid it's not an option.
Anyway, I think I've solved the problem. There is an utility, "foamCalc components U", which is equivalent to former "Ucomponents", so that it's possible to calculate mass flow rate in paraview 3.3 with the previously described method 2 (which I think is much better in terms of accuracy).
Marta
Thread Tools
Trackbacks are On
Mass flow rate of the DPM mass sourse ?? Rhinocao FLUENT 3 January 21, 2011 13:10
DMP mass flow rate Don Parsons FLUENT 3 April 17, 2007 02:30
mass flow rate---------- mech FLUENT 1 May 12, 2006 03:54
Mass flux and mass flow rate us Phoenics 10 March 31, 2006 02:06
How are the mass flux and mass flow rate defined? Miles CD-adapco 2 November 7, 2002 09:45
