Home > Forums > OpenFOAM Paraview & paraFoam
Paraview and VTK
Like Tree1Likes
Old   May 11, 2005, 09:55
Default Hi, I am not able to take a
  #81
Fabian Braennstroem
braennstroem is on a distinguished road
I am not able to take a look at the results and grid with paraview/paraFoam anymore. It worked before and I don't know what I changed.
If I choose the 'normal' way by the utilities-menu to postprocess the data with parafoam, paraview opens up normal, but pressing the 'accept' button it seems that paraview wants to load the data and closes the environment afterwards. OpenFoam than tells me that the 'Application parafoam (pid ...) did finish successfully', but I don't want to finish it before I can see anything...
Does anybody have an idea what went wrong?
Greetings!
Fabian
braennstroem is offline   Reply With Quote
Old   May 11, 2005, 11:13
Default Hi, I just tested it from the
  #82
Fabian Braennstroem
I just tested it from the console with
'paraFoam OpenFOAM/fab-1.1/run/tutorials/buoyantFoam/ hotRoom'
I get as error message:
'/home/fab/OpenFOAM/OpenFOAM-1.1/bin/paraFoam: line 57: 7023 Segmentation fault paraview paraFoam.pvs'
Does anybody understand this?
Greetings!
Fabian
Old   May 11, 2005, 15:32
Default Well, reading the error messag
  #83
Hrvoje Jasak
Well, reading the error message tells me:
0) try running paraview on its own (this will check the installation
1) get rid of the trailing "/" in the root entry on the command line:
'paraFoam OpenFOAM/fab-1.1/run/tutorials/buoyantFoam hotRoom'
2) Try deleting all old paraview files in the case directory and try again.
Hrv
Hrvoje Jasak
Old   May 12, 2005, 01:40
Default Hi, thanks for the suggesti
  #84
Fabian Braennstroem
thanks for the suggestions, unfortunately it does not help...
I checked paraview on his own, which works fine, got rid of the trailing '/' and deleted old paraview files. Strange!
Fabian
Old   May 12, 2005, 01:56
Default Hi, it works fine for a diffe
  #85
Fabian Braennstroem
it works fine for a different problem 'turboFoam cavity'; from command line and gui
Fabian
Old   May 12, 2005, 02:48
Default Your probably have NaN-s or si
  #86
Hrvoje Jasak
Your probably have NaN-s or similar garbage in one of your result files. I have seen this before.
Hrv
Hrvoje Jasak
Old   May 12, 2005, 06:54
Default Yes, I have some NaN-s... T
  #87
Fabian Braennstroem
Thanks.
Fabian
Old   May 12, 2005, 06:55
Default :-) Nans are good in an Indian
  #88
Hrvoje Jasak
:-) Nans are good in an Indian restaurant, but not in a CFD solution... I hope all will be wlel when you get rid of them.
Enjoy,
Hrv
Hrvoje Jasak
  #89
Hrvoje Jasak
:-) Nans are good in an Indian restaurant, but not in a CFD solution... I hope all will be well when you get rid of them.
Enjoy,
Hrv
sharonyue likes this.
Hrvoje Jasak
Old   May 18, 2005, 03:31
Default Hi all, Does anybody know i
  #90
Ervin Adorean
adorean is on a distinguished road
Hi all,
Does anybody know if it is possible to mirror the geometry in Paraview; if yes, how?
Thanks
Ervin
adorean is offline   Reply With Quote
Old   May 18, 2005, 03:44
Default Filter->Reflection (have ne
  #91
Mattijs Janssens
mattijs is on a distinguished road
Filter->Reflection
(have never tried it though)
Or use OpenFOAM utility mirrorMesh to build a symmetric mesh (not sure if it does fields as well)
mattijs is offline   Reply With Quote
Old   May 18, 2005, 04:04
Default Thanks Mattijs, It did work
  #92
Ervin Adorean
Thanks Mattijs,
It did work with Filter -> Reflection
Old   July 14, 2005, 09:35
Default Hi All, I have been trying
  #93
kanishka
Hi All,
I have been trying to do the lid-driven cavity flow tutorial.Post-processing with paraFoam shows the following error:
[kanishka@fedora1 ~]$ paraFoam $FOAM_RUN/tutorials/icoFoam cavity
ErrorMessage
# Error or warning: ERROR: In /home/amy/ParaViewReleaseRoot/paraview-2.0.2/Utilities/VTKClientServer/vtkClient ServerInterpreter.cxx, line 882
vtkClientServerInterpreter (0x8973a48): Cannot load module "PVFoamReader" from "/home/kanishka/OpenFOAM/OpenFOAM-1.1/lib/linuxOpt/libPVFoamReader.so".
ERROR: In /home/amy/ParaViewReleaseRoot/paraview-2.0.2/Utilities/VTKClientServer/vtkClient ServerInterpreter.cxx, line 886
vtkClientServerInterpreter (0x8973a48): /home/kanishka/OpenFOAM/OpenFOAM-1.1/lib/linuxOpt/libPVFoamReader.so: undefined symbol: _ZN9vtkObject8RegisterEP13vtkObjectBase
ERROR: In /home/amy/ParaViewReleaseRoot/paraview-2.0.2/GUI/Client/vtkPVXMLPackageParser.cx x, line 675
vtkPVXMLPackageParser (0x9116ab0): Error loading Library component PVFoamReader
ErrorMessage end
/home/kanishka/OpenFOAM/OpenFOAM-1.1/bin/paraFoam: line 57: 4039 Segmentation fault paraview paraFoam.pvs
...in this the ParaFoam window shuts down as soon as it opens up!
Although there is no such problem with paraview
which i had separately installed after downloading it from paraview.org.
Any ideas???can this problem be sorted out by some means...Do i install OpenFoam to the system again?
Cheers
Kanishka
Old   July 14, 2005, 09:42
Default The PVFoamReader is compiled f
  #94
henry is on a distinguished road
The PVFoamReader is compiled for ParaView-1.8.5 not for ParaView-2.0.2. Your options are:
1) install the ParaView-1.8.5 we supply with OpenFOAM-1.1
2) recompile PVFoamReader for ParaView-2.0.2 (but it probably won't work due to changes in ParaView)
3) use the foamToVTK converter and run paraview rather than paraFoam.
henry is offline   Reply With Quote
Old   July 27, 2005, 11:35
Default Hi, I want to do parts of my
  #95
Rolando Maier
rolando is on a distinguished road
I want to do parts of my postprocessing on a windows machine. I installed a binary version of "paraview" there.
I intend to convert my simulation data into VTK format with "foamToVTK", put it on my windows machine and doing the visualization.
Will it be identical to calling "paraFoam" with the corresponding case?
Rolando
rolando is offline   Reply With Quote
Old   July 27, 2005, 12:24
Default Hi Henry, Please tell me ho
  #96
kanishka
Hi Henry,
Please tell me how to install ParaView-1.8.5 over ParaView-2.0.2.I am struggling with 'rpm -e' command to do so,not having much knowledge of commandline interface.How to use 'foamToVTK' converter?
And how to do post-processing with dxFoam.
'dxFoam postFoam' shows the following message:
Executing: /home/kanishka/OpenFOAM/OpenFOAM-1.1/.bashrc
Executing: /home/kanishka/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/apps/dxFoam/bashrcExecuting: /home/kanishka/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/apps/ensightFoam/bashrc
Executing: /home/kanishka/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/apps/paraview/bashrc
[kanishka@fedora1 ~]$ dxFoam postFoam
Checking path to dx ...
Checking path to dxFoamExec executable ...
Can't find dxFoamExec executable. Please check your path.
I have downloaded the installer files of OpenDX from http://www.opendx.org/dlBinary.php
While installing it shows:
[kanishka@fedora1 ~]$ rpm -Uvh opendx-4.3.2-1.rh9.rpm
error: can't create transaction lock
how to install and work with it??
..please suggest something.
Kanishka
Old   July 27, 2005, 15:30
Default To install ParaView-1.8.5 avai
  #97
To install ParaView-1.8.5 available from the OpenFOAM download site follow the instructions supplied.
Use foamToVTK in the same manner as all the other OpenFOAM utilities. Usage is described in the documentation.
dxFoam is no longer supported.
Old   August 27, 2005, 18:37
Default I am trying to use foamToVTK o
  #98
Ales Alajbegovic
alajbegovic is on a distinguished road
I am trying to use foamToVTK on the buoyantFoam case. I get the error shown below when using it after the simulation. What do I have to do?
Time constant
volScalarFields :
volVectorFields :
pointScalarFields :
pointVectorFields :
Internal : "/home/ales/OpenFOAM/ales-1.2/run/tutorials/buoyantFoam/hotRoom/VTK/hotRoom_0.vt k"
Original cells:4000 points:4851 Additional cells:0 additional points:0
Patch : "/home/ales/OpenFOAM/ales-1.2/run/tutorials/buoyantFoam/hotRoom/VTK/floor/floor_ 0.vtk"
Patch : "/home/ales/OpenFOAM/ales-1.2/run/tutorials/buoyantFoam/hotRoom/VTK/ceiling/ceil ing_0.vtk"
Patch : "/home/ales/OpenFOAM/ales-1.2/run/tutorials/buoyantFoam/hotRoom/VTK/fixedWalls/f ixedWalls_0.vtk"
Time 0
--> FOAM FATAL IO ERROR :
Cannot find 'value' entry which is required to set the values of the default patch field.
Please add the 'value' entry to the write function of the user-defined boundary-condition
or link the boundary-condition into libfoamUtil.so
file: /home/ales/OpenFOAM/ales-1.2/run/tutorials/buoyantFoam/hotRoom/0/p::floor from line 34 to line 34.
From function defaultFvPatchField<type>::defaultFvPatchField(con st fvPatch&, const Field<type>&, const dictionary&)
in file fields/fvPatchFields/basicFvPatchFields/default/defaultFvPatchField.C at line 127.
FOAM exiting
alajbegovic is offline   Reply With Quote
Old   August 27, 2005, 18:47
Default Bug in tutorial setup, maybe a
  #99
Hrvoje Jasak
Bug in tutorial setup, maybe also in FoamX config, but I'm not checking. Edit the file:
OpenFOAM-1.2/tutorials/buoyantFoam/hotRoom/0/p and for all patches of type wallBuoyantPressure add the "default" value for post-processing, e.g.:
floor
type wallBuoyantPressure;
value uniform 100000;
Hrv
Hrvoje Jasak
Old   November 16, 2005, 14:50
Default Dear all: I have a VTK file
  #100
Guoxiang
liugx212 is on a distinguished road
Dear all:
I have a VTK file in which includes the MESH and Geometry. But I do not know how to import to openfoam or how to use this VTK file in openfoam. Could you help me.
Thanks deeply,
Guoxiang
liugx212 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Paraview 34 hsieh OpenFOAM Paraview & paraFoam 4 January 26, 2009 15:31
Paraview 300 vinz OpenFOAM Paraview & paraFoam 12 October 6, 2007 09:46
Paraview peter ParaView 0 November 29, 2006 02:47
Paraview jojo ParaView 4 June 25, 2006 19:01
HI all I cant find display button in paraview when i execute cavity tutorial there is only parameter button in the paraview chan OpenFOAM Paraview & paraFoam 2 February 13, 2006 08:37
