Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] ParaView 33 canbt open OpenFoam file
Old   August 28, 2008, 06:45
Default ParaView 33 canbt open OpenFoam file
Hari Krishnan
hariya03 is on a distinguished road
Dear to all,
I have tried to open the cavity/icoFoam case file after solved. But the paraview asking to choose a appropriate reader to open the file.
When I choose the OpenFOAM files option it was crashed and exit with saying the below comments,
terminate called after throwing an instance of 'std::length_error'
what(): basic_string::_S_create
/home/harikr/OpenFOAM/OpenFOAM-1.5/bin/paraFoam: line 83: 13772 Aborted paraview --data=$caseFile
I have did the 7th step as like in READ ME for rebuilding and compiling the paraView and PV3Foam Reader using the steps as mentioned there.
But it results in unable to open the Paraview window itself after running the ./Allwmake.
I can work with converting into VTK formats and can open the file through in legacy vtk files.
But I would like to read the .OpenFOAM file.. the real one..
Could anybody advice me in this regard?
Kindly ask me if you need any more information.
Thanks in Advance.
Hari Krishnan.V
hariya03 is offline   Reply With Quote
Old   August 28, 2008, 12:37
Default Hello, You can find some in
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
You can find some information related to your problem in:
http://www.cfd-online.com/OpenFOAM_D...tml?1219785334
Please note that I also had the problem you reported, and was able to fix it by following the instructions from that thread (look for my post).
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   August 29, 2008, 08:44
Default Dear Mr.Jose and to all,
Hari Krishnan
Thank you for your reply. I have tried as like said in the thread.
I have commented the Cmakelists.txt as said in the thread
# MESSAGE(SEND_ERROR "Qt ${QTVERSION} not supported. Please use Qt 4.3 (you may need to clean your dirtied cache).")
I have installed the libqt4 all the packages through YasT. and after that I rebuild the paraView3.3-cvs and PV3Foam Reader. I got the result as below.
harikr@hari:~/OpenFOAM/ThirdParty> rm -rf ParaView3.3-cvs/platforms
harikr@hari:~/OpenFOAM/ThirdParty> buildParaView3.3-cvs
Building ParaView3.3-cvs
MPI support : OFF
Python support : OFF
MESA support : OFF
Source : /home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc
-- Check for working C compiler: /home/harikr/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
-- Check for working C compiler: /home/harikr/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- broken
CMake Error: The C compiler "/home/harikr/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc" is not able to compile a simple test program.
It fails with the following output:
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build
gmake[1]: Entering directory `/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp'
/home/harikr/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o
/home/harikr/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/testCCompiler.c
/home/harikr/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i6 86-pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
gmake[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1
gmake[1]: Leaving directory `/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp'
gmake: *** [cmTryCompileExec/fast] Error 2
CMake will not be able to correctly generate this project.
-- Configuring done
make: *** No targets specified and no makefile found. Stop.
done
harikr@hari:~/OpenFOAM/ThirdParty> cd..
harikr@hari:~/OpenFOAM> cd OpenFOAM-1.5
harikr@hari:~/OpenFOAM/OpenFOAM-1.5> cd applications/utilities/postProcessing/graphics/PV3FoamReader/
harikr@hari:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamR eader> ls
Allwclean Allwmake PV3FoamReader vtkPV3Foam
harikr@hari:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamR eader> ./Allwclean
+ rm -r PV3FoamReader/Make
+ wclean libso vtkPV3Foam
wclean vtkPV3Foam
harikr@hari:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamR eader> ./Allwmake
+ '[' -d /home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -a -r /home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc ']'
+ case "$ParaView_VERSION" in
+ wmake libso vtkPV3Foam
wmakeLnInclude: linking include files to /home/harikr/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphic s/PV3FoamReader/vtkPV3Foam/lnInclude
Making dependency list for source file vtkPV3Foam.C
could not open file vtkConfigure.h for source file vtkPV3Foam.C
Making dependency list for source file vtkPV3FoamAddVolumeMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddVolumeMesh.C
Making dependency list for source file vtkPV3FoamAddLagrangianMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddLagrangianMesh.C
Making dependency list for source file vtkPV3FoamAddPatchMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddPatchMesh.C
Making dependency list for source file vtkPV3FoamAddFaceZoneMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddFaceZoneMesh.C
Making dependency list for source file vtkPV3FoamAddPointZoneMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddPointZoneMesh.C
Making dependency list for source file vtkPV3FoamAddFaceSetMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddFaceSetMesh.C
Making dependency list for source file vtkPV3FoamAddPointSetMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddPointSetMesh.C
Making dependency list for source file vtkPV3FoamUpdate.C
could not open file vtkConfigure.h for source file vtkPV3FoamUpdate.C
Making dependency list for source file vtkPV3FoamUpdateInformation.C
could not open file vtkConfigure.h for source file vtkPV3FoamUpdateInformation.C
Making dependency list for source file vtkPV3FoamConvertMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamConvertMesh.C
SOURCE=vtkPV3Foam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/harikr/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/harikr/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/harikr/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/harikr/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/harikr/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/harikr/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3Foam.o
/home/harikr/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i6 86-pc-linux-gnu/4.3.1/cc1plus: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
make: *** [Make/linuxGccDPOpt/vtkPV3Foam.o] Error 1
+ cd PV3FoamReader
+ mkdir -p Make/linuxGccDPOpt
+ cd Make/linuxGccDPOpt
+ cmake ../..
gmake[1]: Entering directory `/home/harikr/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphi cs/PV3FoamReader/PV3FoamReader/Make/linuxGccDPOpt/CMakeFiles/CMakeTmp'
/home/harikr/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/harikr/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/Make/linuxGccDPOpt/CMakeFiles/CMakeTmp/CMakeFiles 1
/home/harikr/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/harikr/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/Make/linuxGccDPOpt/CMakeFiles/CMakeTmp/testCCompil er.c
gmake[1]: Leaving directory `/home/harikr/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphi cs/PV3FoamReader/PV3FoamReader/Make/linuxGccDPOpt/CMakeFiles/CMakeTmp'
-- Configuring done
+ make
When I tend to run ParaFoam, I can't enter into paraview3.3 itself. It results like as below:
harikr@hari:~/OpenFOAM/harikr-1.5/run/tutorials/icoFoam/cavity> paraFoam
/home/harikr/OpenFOAM/OpenFOAM-1.5/bin/paraFoam: line 100: paraview: command not found
Could you/anyone advice me in this regard?
Thank you
V.Hari Krishnan
Old   August 29, 2008, 09:34
Default Hi, From the error messages
santos's Avatar
Jose Luis Santos
From the error messages you got, I think it may be related to gcc:
Check whether you downloaded the correct files for your system (32 bits / 64 bits). You may also try to use your system gcc compiler.
Regards,
Jose Santos
Old   September 18, 2008, 04:21
Default Dear hari and Jose I have e
Ameya Durve
ameya is on a distinguished road
Dear hari and Jose
I have exactly the same problem as you do.
But as mr. jose has suggested the problem must be of gcc.
I tried that but no effect.
My gcc version is 4.3.1. Yet i am getting the ame problem. i dont think this problem is of gcc.
ameya is offline   Reply With Quote
Old   September 18, 2008, 17:30
Default Dear Ameya, What is the out
santos's Avatar
Jose Luis Santos
Dear Ameya,
What is the output of foamInstallationTest? Any fatal error?
A quick way to check if gcc is correctly installed would be:
foamInstallationTest | grep gcc
My output is:
gcc 4.3.1 .../OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
Old   September 20, 2008, 08:52
Default hello, i have the same prob
eidam655
hello,
i have the same problem, with qt 4.3.x (don't remember the exact version now) and stock packages. paraview runs, but paraFoam cannot open .OpenFOAM files - if i choose the OpenFOAM file reader option, nothing happens - only abunch of error messages (the same as described in post #0 here).
any ideas? while trying to recompile, i got stuck at 26% of building.
Old   September 25, 2008, 17:33
Default any ideas?
eidam655
any ideas?
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
