[OpenFOAM] Too many time folders crash foamToVTK
Old   September 22, 2008, 05:21
Default Too many time folders crash foamToVTK
John Deas
johndeas is on a distinguished road
I am using foamToVTK on my Ubuntu machine (I need to export the VTK folder to postprocess on another machine).
On version 1.5, if I have too many time folders in my case (around 50 it seems) I get this error notification:
--> FOAM Serious Error :
Too many errors#0 Foam::error::printStack(Foam:stream&) in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#1 Foam::error::abort() in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#2 Foam:stream& Foam::operator<<>(Foam:stream&, Foam::errorManip<foam::error>) in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/applications/bin/linux64Gc cDPOpt/foamToVTK"
#3 Foam::messageStream::operator Foam:Sstream&() in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#4 Foam::messageStream::operator()(char const*, char const*, int, Foam::string const&, int, int) in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#5 Foam::messageStream::operator()(char const*, char const*, int, Foam::IOstream const&) in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#6 Foam::IOobject::readHeader(Foam::Istream&) in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#7 Foam::IOobject::headerOk() in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#8 Foam::IOobjectList::IOobjectList(Foam::objectRegis try const&, Foam::fileName const&, Foam::fileName const&) in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpe nFOAM.so"
#9 main in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/applications/bin/linux64Gc cDPOpt/foamToVTK"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 Foam::regIOobject::readIfModified() in "/home/flurec/commun/OpenFOAM/1.5-x86_64/OpenFOAM-1.5/applications/bin/linux64Gc cDPOpt/foamToVTK"
From function messageStream::operator OSstream&()
in file lnInclude/messageStream.C at line 203.
FOAM aborting
Abandon
Can anyone help ? Thank you ?
johndeas is offline   Reply With Quote
Old   September 22, 2008, 07:36
Default only 50? thats nothing. dis
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
disk full perhaps?
1 create a bck directory,
2 move the last timestep to the bck-dir.
3 run foamToVTK
4 if it fails go to 2
5 it works - you've found the directory causing the problem.
or move all timesteps to the bck directory and then move them back 1 by 1 until it fails.
It could be that you've lost the connection for a while to the disk while writing the data (if you're working agains an nfs disk or similar)
niklas is offline   Reply With Quote
Old   September 22, 2008, 12:06
Default I have found a workaround: I l
John Deas
I have found a workaround: I launch
foamToVTK -time xxx
using a script, for all my timesteps. It works, so the problem really is the number of time directories, and not a specific one. I have the same problem with both redhat and ubuntu.
Old   September 23, 2008, 15:04
Default Hi John, Very strange. Do y
Mattijs Janssens
Hi John,
Very strange. Do you have sample case that goes wrong? Or can you just do an 'ls' so we can see what time directories you have.
Old   September 25, 2008, 15:07
Default I tried at home outputing 75 t
John Deas
I tried at home outputing 75 time directories and importing them without problem to paraview. I though it was related to my linux distro but it is not then. I will try to isolate more the problem then report here.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
