Parafoam problem
I'm in the install/testrun phase of openfoam 1.4.1. Installing all binaries of openfoam and using paraview 3.2.1 (latest) which was installed systemwide. Everything else is running fine (java, gcc installed systemwide as opposed to under a subdirectory within /home/openfoam). The problem is when running parafoam, i got this error message; Got unknown argument: paraFoam.pvs paraFoam.pvs is there, so is the parafoam.pvs that came with openfoam1.4.1 not compatible with paraview 3.2.1 since the paraview that comes with openfoam is paraview 2.4.4? Anyway to solve this? Thanks |
Hi
The paraFoam works to my
Hi
The paraFoam works to my knowledge only with the paraview 2.x.x not with the paraview 3.x.x. Just download the paraview which comes with OpenFoam. There is possibility to use paraview > 3.2.2 (or so) with a native reader, check the forum Native ParaView Reader Jens |
Thanks Jens! Ooooo... more rea
Thanks Jens! Ooooo... more reading and sleepless nights for me...
ParaFoam crashes in my install
ParaFoam crashes in my install of Ubuntu 7.10. and kills my session and restarts to the user login screen. Has anyone had this problem recently and how did you resolve it? My installation worked about 2 months ago before I switched to Fluent...now that I'm back on OF, using paraview/parafoam and it seems to hate me. Thoughts?
Hi
I am novice running OF o
Hi
I am novice running OF on Ubuntu 7.10. I managed to get the installation system check and installation test passed with only following two unset env variables. $LAM_ARCH_PATH is mentioned critical. (see below) I did manage to run first example with icoFoam cavity and could use FoamX. There the double click was not functional instead right mouse click seemed to do the job. I was not able to start paraFoam but found following error message. What should i do juhani@ubuntujuhani:~/OpenFOAM/OpenFOAM-1.4.1/bin$ paraFoam $FOAM_RUN/tutorials/icoFoam cavity /home/juhani/OpenFOAM/linux64/paraview-2.4.4/lib/paraview-2.4/paraview-real: error while loading shared libraries: libtcl8.4.so: cannot open shared object file: No such file or directory $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...M/OpenFOAM-1.4.1/lib/linux64GccDPOpt yes yes yes $FOAM_USER_LIBBIN ...OAM/juhani-1.4.1/lib/linux64GccDPOpt yes yes no $LAM_ARCH_PATH --------- env variable not set --------- yes |
@Daniel,
I've had this pro
@Daniel,
I've had this problem and filed a bug report for ubuntu https://bugs.launchpad.net/ubuntu/+s...el/+bug/181943 It may be fixed in the next release of ubuntu (due shortly). It might be worth leaving a comment if your graphics card is not the same as mine (mine's an intel X3100). Cheers, Andrew |
Andrew,
what a coincidence.
Andrew,
what a coincidence... mine is also an intel X3100 GMA965. However, paraFoam will work slightly (crash only on more intensive and complicated geometries) if you run it in safe mode, disable all of the fancy effects, and talk really nice to your computer. I found that useful as a short term fix. I hope it will be fixed in the next release of Ubuntu! Dan |
Andrew, Daniel,
I have simi
Andrew, Daniel,
I have similar problems: starting paraview causes Linux / KDE to logout. It happens with paraview 3.2.1 but also with version 2.4.4. Videocard is MGA G550 AGP. However some time ago I had the same on a labtop with a different card (Intel if I am right). There I resolved the issue by installing paraview-3.2.1. However now this shows not to work. I probably have to update some package but I have no idea which one. Any ideas here? Brgds, Mark |
Mark,
I wish I could help.
Mark,
I wish I could help. I ended up either updating Ubuntu 7.10 to 8.04 or reinstalling Ubuntu out of frustration. I imagine that this isn't an option for you and its a bit overkill. I am running Paraview 3.3 pretty well right now without any problems. I do remember that I logged into safe mode to make things usable. Also disabling desktop effects seemed to be a big part of the problem as well as removing all of the fancy desktop effects completely. After those changes, I believe it worked. Dan |
Hi Mark
Try to add the foll
Hi Mark
Try to add the following to /etc/X11/xorg.conf in the section "serverLayout" Option "AIGLX" "false" I did help on some graphical problems. What it does, is that it turn off all special effects as mentioned by Daniel. / Niels |
Hi Niels, Dan,
Thanks for y
Hi Niels, Dan,
Thanks for yuor help. I tried already the Option AIGLX false. It looked like it worked: paraview continued to start without logging off. However then I was not able to do anything. The buttons did not react on any click. paraview.org isn't very helpfull here as well. Search continues, Mark |
Sorry to hear that it didn't h
Sorry to hear that it didn't help. I had similar problems with complete crash of X11 on Fedora 9, and installed Ubuntu 8.04.1.
Here the AIGLX solved the problems. / Niels |
Hi,I use Fedora9,have ever had
Hi,I use Fedora9,have ever had similiar but not the same problem when I use "visit". If I click on any menus,then X was killed and I was kicked out immediately.
The time to find the reason is really long,finally I find that ,If I delete the line with "backingstore" in xorg.conf,then everything is ok. This staff was added by myself for some reason. So my advice is that,if you have ever changed the xorg.conf file,just restore it to the original file and check whether it works.Losing some functionality is better than get X killed. |
