Paraview command not found
Hello!
I canīt get paraFoam to start. It says: "OpenFOAM-1.4/bin/paraFoam: line 67: paraview: command not found" I guess its a simple problem to fix but my skills in OpenFoam and C++ are not the best....yet :-) Any clues out there!! Thank you!! /H |
Did you forget to install para
Did you forget to install paraview in addition to OpenFOAM (general and binary).
Did you compile OpenFOAM from
Did you compile OpenFOAM from source? If so I found that it took some hacking to get parafoam to compile. Unfortunately they don't distribute a tar ball of the paraview source that OpenFOAM expects so you have to track down some header files in the official paraview source tree.
Hello!
Is there some kind o
Hello!
Is there some kind of installation instruction for paraview available somewhere?? /H |
Hello Hardy,
A Good evening
Hello Hardy,
A Good evening to you! Are you looking for instructions for installing the Binary version of ParaView (The version which you dont need to compile), or do you want to actually compile Paraview on your computer ? In case you want to just install the Binaries, then all you need to do is to download the right version (32 bit or 64 bit) of the ParaView binaries from the "downloads" section of the OpenFOAM website, and unzip it into one of the following folders: [your OpenFOAM directory]/linux <-- If its a 32 bit version [your OpenFOAM directory]/linux64 <-- If its a 64 bit version This should be all you need to do... then, the command "paraFoam <root> <case>" should bring up the Paraview interface. On the other hand, if you want to recompile Paraview, its a little more complex, and if you want to do this, let me know, and I can give you the instructions :-)! Enjoy! Philippose |
Philippose,
Perhaps you cou
Philippose,
Perhaps you could put directions to compiling paraview to work with OpenFOAM on the wiki as not everybody uses an x86 processor and there are no other precompiled binary files for other archs. Conn |
hi i am having the same proble
hi i am having the same problem as the post here
mayank-guptas-macbook:icoFoam mayankgupta$ paraFoam ~/openfoam/mayank-1.4.1/run/icoFoam cavity /Users/mayankgupta/OpenFOAM/OpenFOAM-1.4.1/bin/paraFoam: line 75: paraview: command not found the thing is i m using macintosh and i have installed paraview as a disk image.......can some please help and let me know what to do in order to visualize the mesh |
Hello All,
During installat
Hello All,
During installation of ParaView, I got following error . After [Ameya@localhost PV3FoamReader]$ ./Allwmake I got following error + '[' -d /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -a -r /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc ']' + case "$ParaView_VERSION" in + wmake libso vtkPV3Foam wmakeLnInclude: linking include files to /home/Ameya/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/vtkPV3Foam/lnInclude Making dependency list for source file vtkPV3Foam.C Making dependency list for source file vtkPV3FoamAddVolumeMesh.C Making dependency list for source file vtkPV3FoamAddLagrangianMesh.C Making dependency list for source file vtkPV3FoamAddPatchMesh.C Making dependency list for source file vtkPV3FoamAddFaceZoneMesh.C Making dependency list for source file vtkPV3FoamAddPointZoneMesh.C Making dependency list for source file vtkPV3FoamAddFaceSetMesh.C Making dependency list for source file vtkPV3FoamAddPointSetMesh.C Making dependency list for source file vtkPV3FoamUpdate.C Making dependency list for source file vtkPV3FoamUpdateInformation.C Making dependency list for source file vtkPV3FoamConvertMesh.C SOURCE=vtkPV3Foam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3Foam.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkAlgorithm.h:32, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkMultiBlockDataS etAlgorithm.h:25, from ../PV3FoamReader/vtkPV3FoamReader.h:26, from vtkPV3Foam.C:36: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamAddVolumeMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamAddVolumeMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkPoints.h:23, from vtkPV3FoamInsertNextPoint.H:34, from vtkPV3FoamAddVolumeMesh.C:39: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamAddLagrangianMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamAddLagrangianMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkPoints.h:23, from vtkPV3FoamInsertNextPoint.H:34, from vtkPV3FoamAddLagrangianMesh.C:35: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamAddPatchMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamAddPatchMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkPoints.h:23, from vtkPV3FoamInsertNextPoint.H:34, from vtkPV3FoamAddPatchMesh.C:34: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamAddFaceZoneMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamAddFaceZoneMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkPoints.h:23, from vtkPV3FoamInsertNextPoint.H:34, from vtkPV3FoamAddFaceZoneMesh.C:32: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamAddPointZoneMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamAddPointZoneMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkPoints.h:23, from vtkPV3FoamInsertNextPoint.H:34, from vtkPV3FoamAddPointZoneMesh.C:32: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamAddFaceSetMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamAddFaceSetMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkPoints.h:23, from vtkPV3FoamInsertNextPoint.H:34, from vtkPV3FoamAddFaceSetMesh.C:33: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamAddPointSetMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamAddPointSetMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkPoints.h:23, from vtkPV3FoamInsertNextPoint.H:34, from vtkPV3FoamAddPointSetMesh.C:33: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamUpdate.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamUpdate.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkAlgorithm.h:32, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkMultiBlockDataS etAlgorithm.h:25, from ../PV3FoamReader/vtkPV3FoamReader.h:26, from vtkPV3FoamUpdate.C:33: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamUpdateInformation.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamUpdateInformation.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkAlgorithm.h:32, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkMultiBlockDataS etAlgorithm.h:25, from ../PV3FoamReader/vtkPV3FoamReader.h:26, from vtkPV3FoamUpdateInformation.C:39: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. SOURCE=vtkPV3FoamConvertMesh.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/vtkPV3FoamConvertMesh.o In file included from /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/strstream:51, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:4 0, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkAlgorithm.h:32, from /home/Ameya/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkMultiBlockDataS etAlgorithm.h:25, from ../PV3FoamReader/vtkPV3FoamReader.h:26, from vtkPV3FoamConvertMesh.C:36: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/../lib/gcc/i686-pc-linux-gnu /4.3.1/../../../../include/c++/4.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. '/home/Ameya/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libvtkPV3Foam.so' is up to date. + cd PV3FoamReader + mkdir -p Make/linuxGccDPOpt + cd Make/linuxGccDPOpt + cmake ../.. -- Check for working C compiler: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/gcc -- Check for working C compiler: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/gcc -- works -- Check size of void* -- Check size of void* - done -- Check for working CXX compiler: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/c++ -- Check for working CXX compiler: /home/Ameya/OpenFOAM/ThirdParty/gcc-4.3.1/linux/bin/c++ -- works -- Loading ParaView CMake commands -- Loading ParaView CMake commands - done CMake Error: Error in cmake code at #ifndef _@PLUGIN_NAME@Plugin_h:458: Unknown CMake command "QT4_WRAP_CPP". CMake Error: Error in cmake code at /home/Ameya/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/PV3FoamReader/CMakeLists.txt:44: A command failed during the invocation of macro "ADD_PARAVIEW_GUI_EXTENSION". CMake Error: Error in cmake code at #ifndef _@PLUGIN_NAME@Plugin_h:562: ADD_PARAVIEW_GUI_EXTENSION unknown error. Current CMake stack: /home/Ameya/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/PV3FoamReader/CMakeLists.txt;/home/Ameya/OpenFOAM/ThirdParty/cmak e-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCInformation.cmake;/home/Am eya/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMak eCXXInformation.cmake CMake Error: Error in cmake code at /home/Ameya/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/PV3FoamReader/CMakeLists.txt:44: A command failed during the invocation of macro "ADD_PARAVIEW_PLUGIN". CMake Error: Error in cmake code at /home/Ameya/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/PV3FoamReader/CMakeLists.txt:43: ADD_PARAVIEW_PLUGIN unknown error. Current CMake stack: /home/Ameya/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/PV3FoamReader/CMakeLists.txt;/home/Ameya/OpenFOAM/ThirdParty/cmak e-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCInformation.cmake;/home/Am eya/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMak eCXXInformation.cmake -- Configuring done + make make: *** No targets specified and no makefile found. Stop. it seems that the problem is of cmake Any help will be apprecited IO am using Fedora 8 |
