Home > Forums > OpenFOAM Paraview & paraFoam
ParaFoam problem with cavity case
Old   July 19, 2008, 10:25
Default Hi! I started the "cavity"
mayol
roger is on a distinguished road
Hi!
I started the "cavity" case (chapter 2: tutorials, page U-26) the other day, I have no problem running the case in FoamX, but I can't view the mesh created in paraFoam. There's a message that says:
"roger@portatil:~$ paraFoam $FOAM_RUN/tutorials/icoFoam cavity
/home/roger/OpenFOAM/linux/paraview-2.4.4/lib/paraview-2.4/paraview-real: error while loading shared libraries: libXdmf.so: cannot open shared object file: No such file or directory
Does anyone know what "libXdmf.so" is? Thanks in advance. Maybe this is a silly question but it's my first time with OF. Bye!!
roger is offline   Reply With Quote
Old   July 19, 2008, 10:40
Default hi mayol can u please tell
mayank gupta
mgz1985 is on a distinguished road
hi mayol
can u please tell me how to view the mesh in paraFoam....I m not using FoamX.....i use a macintosh
mgz1985 is offline   Reply With Quote
Old   July 19, 2008, 10:53
Default The tutorial says: "The paraf
mayol
The tutorial says: "The parafoam post-processing is started by typing at a command prompt"
paraFoam <root> <case>
"i.e. making the appropiate substitutions for <root> path and <case>, paraFoam is executed on cavity by typing"
Then it says: "This launches the Paraview window as shown in picture ... In the selection window, the user can see that Paraview has opened cavity.foam, the module for the cavity case.
Thanks!!
Old   July 19, 2008, 11:06
Default thanx....shall try it......
mayank gupta
Old   July 19, 2008, 11:55
Default i tried what u said but i get
mayank gupta
i tried what u said but i get the following error..
mayank-guptas-macbook:icoFoam mayankgupta$ paraFoam ~/openfoam/mayank-1.4.1/run/icoFoam cavity
/Users/mayankgupta/OpenFOAM/OpenFOAM-1.4.1/bin/paraFoam: line 75: paraview: command not found
Old   July 21, 2008, 10:45
Default Thanks for your help! Is ther
mayol
Thanks for your help! Is there anyone who has followed Chapter 2 of the OF's "User Guide"? What do you do when you want to view the cavity's mesh(part 2.1.2)? Do you have problems with parafoam? Any information would be great, thanks!
Old   July 21, 2008, 12:02
Default i was having problems with par
mayank gupta
i was having problems with parafoam but then i was asked to try
foamToVTK <root> <case>
after this conversion u can open the file in paraview and visualize it....it worked for me hope it works for u
Old   July 22, 2008, 05:17
Default I tried and i have the same me
mayol
I tried and i have the same message than before:
"roger@portatil:~$ paraview
/home/roger/OpenFOAM/linux/paraview-2.4.4/lib/paraview-2.4/paraview-real: error while loading shared libraries: libXdmf.so: cannot open shared object file: No such file or directory"
There's no problem in doing "foamToVTK" but then i can't open paraview (neither paraFoam). I think the problem is produced when "loading shared libraries", but don't know what to do. Thank you guys!
Old   July 25, 2008, 05:20
Default The problem is in the "shared
mayol
The problem is in the "shared libraries". Anyone know what does it mean? I can not open paraFoam "thanks" to the "shared libraries" I think. Thank you!!!
Old   September 16, 2008, 22:00
Default libXdmf.so is a system library
musaddeque hossein
musahossein is on a distinguished road
libXdmf.so is a system library that you will have to install from your boot disk or down load from the internet. Check your boot disk first (if you have one). Not all linux builds will have it.
I dont know what linux distribution you are running - but if you can, you will save a lot of time and effort if you upgrade to SuSE 11.0
I am running OpenFoam 1.5 on SuSE 11.0 w/o any problems (thus far!)
Regarding not being able to load ParaView, I found that I can load ParaView when I call paraFOAM as follows (and NOT paraView as the documentation states), i.e in the cavity directory:
musa@linux-ip9p:~/OpenFOAM/musa-1.5/run/tutorials/icoFoam/cavity> paraFoam
In other words, you should be able to open it in the case folder (i.e, cavity).
Hope this helps
musahossein is offline   Reply With Quote
Thread Tools
Trackbacks are On
ParaFoam step 6 test case michiel09 OpenFOAM Installation 11 July 22, 2009 21:58
ParaFOAM issue with cavity case mschoenberg OpenFOAM Paraview & paraFoam 3 November 21, 2008 04:57
k din't converge for Lid Driven Cavity case Adrian FLUENT 1 October 24, 2008 05:11
Glyph in the cavity case danie OpenFOAM Running, Solving & CFD 0 June 9, 2008 10:09
Problems reading a case cavity into paraFoam red hat 9 anton322322 OpenFOAM Pre-Processing 0 April 11, 2005 13:13
