Home > Forums > OpenFOAM Paraview & paraFoam
ParaFoam out of date libraries
Old   August 29, 2008, 09:44
Default Hello, I have created a mes
Mélanie Piellard
melanie is on a distinguished road
I have created a mesh within Fluent, successfully transposed it into OF 1.5. I have then run potentialFoam and simpleFoam, and I was able to correctly view the results within paraFoam. Then, I ran the solver oodles on the same case, using the latest results from simpleFoam; the computation is running ok, but it is impossible to open the case within paraFoam. I have to precise that in all computations, there are 8 partitions.
After launching paraFoam, I can select the regions and fields to be loaded, then after quite a long time ParaView crashes. The exact error message is:
new cannot satisfy memory request.
This does not necessarily mean you have run out of memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date library.
Do someone have an idea about what is going on ? I always do the post-processing on the same machine, with no other task in the background. I admit that the model is large (8 million hexa cells), but since paraFoam was able to load the simpleFoam and potentialFoam cases I do not understand why the oodles cases causes problems.
Thanks
mélanie
melanie is offline   Reply With Quote
Old   September 9, 2008, 05:45
Default Hello, Actually by converti
Mélanie Piellard
Actually by converting the case to VTK I am able to load it with Paraview 3.3.0 (on the same machine)... I don't know what is causing the bug, does anyone have an idea ? Anyway I can go on working now !
mélanie
Thread Tools
Trackbacks are On
Error Reading date file chnrdu OpenFOAM Running, Solving & CFD 13 January 29, 2013 03:35
Projected Release Date david_h OpenFOAM 0 April 17, 2008 09:48
DATE!! Vinod FLUENT 2 January 25, 2005 05:17
Up-to-date SAE Papers about CFD with cars Omer Dolek Main CFD Forum 0 September 7, 2004 08:04
date contour Rachid CD-adapco 1 June 1, 2000 03:21
