Home > Forums > OpenFOAM Paraview & paraFoam
ParaFoam does not launch
Old   June 3, 2008, 11:53
Default Hi People, with great help
Lawrence
lawrencelkl is on a distinguished road
Hi People,
with great help from the FOAMer here, i managed to install paraFOAM -1.4.1, however, after i test run the icoFOAM cavity case and typed
"paraFoam ./ cavity"
the paraview launch picture appeared for less than a second and then this is the msg i get.
> " Xlib: extension "GLX" missing on display ":0.0".
> /root/OpenFOAM/OpenFOAM-1.4.1/bin/paraFoam:line75:
> 21024 Aborted paraview paraFoam.pvs"
i read some of the earleir discussion and found this :
The proposed workaround is to add the following line to the 'ServerLayout' section in your /etc/X11/xorg.conf. Please make sure to create a backup before you modify it.
For Example:
Section "ServerLayout"
Option "AIGLX" "false"
EndSection
does anyone knows that this is also the right thing to try for my case above?
also, i have downloaded and installed paraview in windows version but have no idea which file should i click on "open", i.e. for the cavity case under icoFoam, which file is stored as the data file to be opened with paraview in windows?
any help and suggestion will be very much appreciated.
cheers
Lawrence
lawrencelkl is offline   Reply With Quote
Old   June 3, 2008, 12:38
Default Try paraFoam . cavity NOT para
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Try paraFoam . cavity NOT paraFoam ./ cavity
Not yet. Try that only if paraFoam crashes when trying to save images.
If you are comfortable with GNU/Linux, then don't waste time trying the setup OpenFOAM in Windows using Cygwin. I don't think it is that trivial.
msrinath80 is offline   Reply With Quote
Old   June 3, 2008, 12:40
Default Oh and a word of advise. Pleas
Oh and a word of advise. Please stop working as root user. It isn't safe at all.
Old   June 4, 2008, 08:22
Default Hi Srinath, i tried the par
Lawrence
Hi Srinath,
i tried the paraFoam . cavity and the same error is reported.
can u please kindly suggest what should i do with the Xlib error?
thanks a lot.
Lawrence
Old   June 4, 2008, 08:48
Default I used to think that paraView
I used to think that paraView would automatically default to software rendering should it not find any hardware GLX support in the Xserver. Maybe I was wrong. You could always try enabling software rendering in the Xserver by turning off the hardware cursor in xorg.conf. Alternately, you might wish to wait for some more time and see if anyone else in this forum can offer a better solution.
Old   June 4, 2008, 09:38
Default Hi Srinath, thanks for your
Lawrence
Hi Srinath,
thanks for your reply. please bear with me as i am completely new to these. may i know how do i turn the hardware cursor off? do you mean i comment out a particular line in the file? if so, which one is that?
Thanks again.
any suggestion from anyone is very much needed and appreciated.
Cheers
Lawrence
Old   June 4, 2008, 12:34
Default Look for a section called Devi
Look for a section called Device in your /etc/xorg.conf file. Just before the EndSection part, add the SWCursor line as shown below:
Section "Device"
Option "SWCursor" "True"
EndSection
Remember that this should only be a last resort as it will severely degrade graphics performance. For all I know you may just be missing some OpenGL libs or using the incorrect driver. Unfortunately I cannot go into details of the same. If you are infamiliar with GNU/Linux, I recommend getting help from someone who knows how to tweak these settings.
Old   July 20, 2008, 09:32
Default hi srinath, i have installe
mayank gupta
mgz1985 is on a distinguished road
hi srinath,
i have installed openfoam-1.4.1 on macintosh as a disk image. i have installed paraview 3.2.1 separately everything seems to be working fine but the paraFoam command gives me an error
mayank-guptas-macbook:icoFoam mayankgupta$ paraFoam ~/openfoam/mayank/run/icoFoam cavity
/Users/mayankgupta/OpenFOAM/OpenFOAM-1.4.1/bin/paraFoam: line 75: paraview: command not found
i am putting the complete putput of my console also...
mayank-guptas-macbook:~ mayankgupta$ . ~/openfoam/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
Executing: /Users/mayankgupta/OpenFOAM/OpenFOAM-1.4.1/.bashrc
Executing: /Users/mayankgupta/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/ensightFoam/bash rc
Executing: /Users/mayankgupta/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/paraview/bashrc
mayank-guptas-macbook:~ mayankgupta$ cd openfoam/mayank/run/icoFoam
mayank-guptas-macbook:icoFoam mayankgupta$ blockMesh . cavity/*------------------------------------------------------------------------ ---*\
Creating patches
Creating block mesh topology
Default patch type set to empty
Creating merge patch pairs
Writing polyMesh
end
mayank-guptas-macbook:icoFoam mayankgupta$ checkMesh . cavity/*-------------....
Mesh OK.
End
i have looked in the forums everywhere relating to this and tried the helps on wiki but i cant seem to get around this problem and when i view the line 75 in the paraFoam file it is as below..
paraview parafoam.pvs
kindly help.
mgz1985 is offline   Reply With Quote
Thread Tools
Trackbacks are On
how to launch a Parallel maxim FLUENT 2 May 29, 2008 09:14
Launch Michele CD-adapco 4 January 10, 2008 06:08
missile launch simulation Mark FLUENT 1 July 11, 2007 17:30
how to launch fluent from C code Hugo FLUENT 2 May 23, 2007 17:11
Launch ProStar in StarDesign ? ingear CD-adapco 6 October 28, 2005 12:21
