[OpenFOAM] Paraview shuts down when post processing of icoFoam |
May 31, 2008, 07:54 |
jin xu
Rep Power: 17 |
Hi, everyone,
for some reasons, I reinstall OF 1.3 in my laptop, and after that, i want to make sure nothing is wrong in my installation by running the cavity(icoFoam) case, but when postprocessing the results, paraview shuts down aotumatically and the error reads: snail@snail-laptop:~/OpenFOAM/snail-1.3/run/tutorials$ paraFoam icoFoam cavity /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Segmentation fault (core dumped) Could anyone give me some ideas? Thanks in advance jin |
June 1, 2008, 20:01 |
The correct command is "paraFo
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
The correct command is "paraFoam . cavity" assuming that you are already at the icoFoam root directory. Please please follow the user guide[1] exactly for once. If you wish to use the full path the syntax is:
paraFoam $FOAM_RUN/tutorials/icoFoam cavity [1] http://www.opencfd.co.uk/openfoam/do...#x5-120002.1.2 |
Display Modes | |
post processing discrete phase with paraview | mighelone | FLUENT | 3 | March 9, 2021 05:34 |
icoFoam won't run while Paraview is running | MikeHersee | OpenFOAM Running, Solving & CFD | 2 | January 6, 2015 06:06 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 07:21 |
[OpenFOAM] is parallel processing available in parafoam for post processing? | sachinlb | ParaView | 1 | August 14, 2012 10:52 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 21:51 |
