-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   Paraview shuts down when post processing of icoFoam (http://www.cfd-online.com/Forums/openfoam-paraview/61144-paraview-shuts-down-when-post-processing-icofoam.html)
jin_xu May 31, 2008 06:54
Hi, everyone, for some reas
Hi, everyone,
for some reasons, I reinstall OF 1.3 in my laptop, and after that, i want to make sure nothing is wrong in my installation by running the cavity(icoFoam) case, but when postprocessing the results, paraview shuts down aotumatically and the error reads:
snail@snail-laptop:~/OpenFOAM/snail-1.3/run/tutorials$ paraFoam icoFoam cavity
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Segmentation fault (core dumped)
Could anyone give me some ideas?
Thanks in advance
jin
msrinath80 June 1, 2008 19:01
The correct command is "paraFo
The correct command is "paraFoam . cavity" assuming that you are already at the icoFoam root directory. Please please follow the user guide[1] exactly for once. If you wish to use the full path the syntax is:
paraFoam $FOAM_RUN/tutorials/icoFoam cavity
[1] http://www.opencfd.co.uk/openfoam/do...#x5-120002.1.2
