[OpenFOAM] Problems of postprocessing of icoStructFoam |
January 7, 2008, 17:13 |
feng wang
Rep Power: 17 |
hi,guys
i want to post-process the results of the icoStructFoam,i did foamToVTK . icoStructFoamTest -mesh region1 foamToVTK . icoStructFoamTest -mesh region2 everything is fine, yet when i did paraFoam $FOAM_RUN/tutorials/icoStructFoam icoStructFoamTest i got errors: --> FOAM FATAL ERROR : Cannot find file "boundary" in directory "constant/polyMesh" From function Time::findInstance(const word& dir, const word& name) in file db/Time/findInstance.C at line 133. FOAM exiting i am a brand new user of OF, so what can i do to solve this error? all the best Feng |
January 8, 2008, 04:28 |
You have already .vtk files (i
Mattijs Janssens
Rep Power: 26 |
You have already .vtk files (in the VTK directory) so you can run straight paraview. No need to run paraFoam (Paraview-with-Foam reader). Just use the file->open menu.
January 8, 2008, 05:36 |
Hi Feng!
An alternate way t
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Feng!
An alternate way to postprocess multi-region cases is described at http://openfoamwiki.net/index.php/Ho...rocMultiregion The advantage of this method is that you can use all the cool feature of paraFoam (time-step names, etc) and don't waste disk-space for the VTK-files. Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
January 8, 2008, 18:02 |
Hi
I think I know how to d
feng wang
Rep Power: 17 |
Hi
I think I know how to do it.i am now trying Deformable channel, but the results is not satisfactory(i should have post the image, but i do not know how to do it,sorry about that).the mesh for the fluid domain is deformed^_^, while the mesh for the structure domain not. i download the solver and this case on the website i post below, so i think the problems may come from the post-processing(i am using version OF 1.3).could anyone tell me how to solve this problem? this is the web site i download the case and sovler http://openfoamwiki.net/index.php/Contrib_icoStructFoam by the way,is there any difference between the method i use and the one recommended by Bernhard? All the best Feng |
January 9, 2008, 07:29 |
Hi Feng!
To visualize the d
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Feng!
To visualize the deformed solid use in paraView/Foam the "Warp Vector"-filter and use the displacement as the deforming value. Then the solid mesh should align with the fluid mesh Bernhard
May 30, 2008, 16:29 |
Hi Feng,
I want to answer y
Ruth Oh
Rep Power: 17 |
Hi Feng,
I want to answer your original query about this error: --> FOAM FATAL ERROR : Cannot find file "boundary" in directory "constant/polyMesh" From function Time::findInstance(const word& dir, const word& name) in file db/Time/findInstance.C at line 133. FOAM exiting I'm likewise new in using OpenFOAM, which is part of the reason why I'm replying so late. One observation that I made is that for any of those cases in the tutorial directory ($FOAM_RUN/tutorials/), there would be the same cases found in the directory one level up (i.e. $FOAM_RUN/). I'm guessing those are the originals that the tutorial copied from. Those originals had additional files in the folder called polyMesh, eg. $FOAM_RUN/oodles/pitzDaily/constant/polyMesh/ has the files points, faces, neighbours, and so on. But the tutorial version of the original won't have those files, eg. $FOAM_RUN/tutorials/oodles/pitzDaily/constant/polyMesh/ doesn't have points, faces, and the rest of those files. I believe these files contain information about the different information for the mesh. Without them, you'll get that error message. I have resorted to use the originals instead of the tutorial version. Perhaps other people could comment about the observation I made and explain better what is going on. |
May 30, 2008, 17:09 |
My mistake, but apparently, th
Ruth Oh
Rep Power: 17 |
My mistake, but apparently, the turbFoam directory's cavity case has points, faces, and those kind of files in polyMesh. So probably, some cases have the necessary points, etc, but not all of them have that.
using fieldAverage library to average postprocessing | eelcovv | OpenFOAM Programming & Development | 32 | May 17, 2022 09:55 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Cyclic patches and parallel postprocessing problems | askjak | OpenFOAM Bugs | 18 | October 27, 2010 03:35 |
postprocessing for icoStructFoam solver | aut_iut | OpenFOAM Post-Processing | 8 | July 28, 2010 05:05 |
[OpenFOAM] ParaView Postprocessing problems with cyclic boundaries | christian | ParaView | 10 | June 26, 2009 05:49 |
