[OpenFOAM] ParaFOAM
Old   May 29, 2008, 08:04
Default ParaFOAM
Hy Yu
ttdtud is on a distinguished road
Hi, everybody, can anyone tell me how could iso-gamma-line of two different times in one picture be showed? e.g. one moving bubble
I appreciate any hints!
ttdtud is offline   Reply With Quote
Old   May 29, 2008, 08:45
Default Open the case with paraFoam .
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Open the case with
paraFoam . case
Then open the case AGAIN via the File->Open in the menu (look for the file case.foam). In both instances of the case you should be able to set a different time. If this doesn't work you can always convert the case with foamToVTK and open different timesteps
BTW: Please be a bit more specific in the title if you open a new thread
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   May 29, 2008, 10:08
Default Thanks a lotfor yourt quick re
Hy Yu
Thanks a lotfor yourt quick reply, Bernhard.
It works by opening case twice.
Sorry, next time i will pay attention. It was my first question in the forum.
[OpenFOAM] Unable to launch parafoam & boonhow ParaView 5 March 23, 2022 09:09
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 18:03
[OpenFOAM] How to use paraFoam on a cluster andreas ParaView 1 March 6, 2013 18:11
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 06:20
[OpenFOAM] ParaFoam OF 14 decomposed cases philippose ParaView 4 April 18, 2007 06:17
