Home > Forums > OpenFOAM Paraview & paraFoam
Cannot find file points in directory constantpolyMesh
Old   March 25, 2008, 03:20
Default Dear frieds: I tried to le
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear frieds:
I tried to learn the first tutorial cavity, but after i started the paraview, and after i click the "accept', the paraview dispear. and it gives me the following error. so what should i do/
fidap run #paraFoam icoFoam/cavity
--> FOAM FATAL ERROR : Cannot find file "points" in directory "constant/polyMesh"
From function Time::findInstance(const word& dir, const word& name)
in file db/Time/findInstance.C at line 133.
FOAM exiting
regards
ztdep is offline   Reply With Quote
Old   March 25, 2008, 05:15
Default Hi ztdep .... strange name :o)
Cedric DUPRAT
cedric_duprat is on a distinguished road
did you check by yourself if there is the points file in constant/polymesh ?
if not, are you sure you created your mesh correctly (blockMesh command) ?
note that if you follow the userguide step by step, it should work correctly.
Regards,
Cedric
cedric_duprat is offline   Reply With Quote
Old   March 25, 2008, 06:20
Default you first need to set up the m
Maximilian Graser
graser is on a distinguished road
you first need to set up the mesh using blockMesh; e.g.:
blockMesh <root> <case>
There should also a possibility doig this directly in FoamX.
Max
graser is offline   Reply With Quote
Old   March 25, 2008, 22:23
Default thank you very much! i have re
ztdep's Avatar
p ding
thank you very much! i have resolve the problem, i just log in as root. then everything is ok
Thread Tools
Trackbacks are On
Cannot find file points in directory constantpolyMesh blo OpenFOAM Installation 4 August 26, 2008 07:06
Error libsslso098 No such file or directory yarrort1 OpenFOAM Installation 1 April 21, 2008 07:30
Cannot find file points derath OpenFOAM Running, Solving & CFD 1 May 4, 2007 12:04
FOAM FATAL ERROR Cannot find file points in directory constantpolyMesh evgenii OpenFOAM Native Meshers: blockMesh 2 October 9, 2006 15:27
File "core" in Fluent directory Ralf Schmidt FLUENT 1 January 15, 2006 12:23
